Bardhal Engine Oils, Made in USA
Established 1939
Proven in racing circuits around the world
Throughout the years Bardahl became involved in all types of racing to serve as a proving ground for its products, along with valuable Research and Development into new technologies. This would include Unlimited Hydroplanes, Offshore Powerboats, Unlimited Airplane Racing, FORMULA-1 cars, INDY cars and CART Racing, NASCAR, Motorcycle and Snowmobile racing to name a few.
Basis For Bardahl Products
When magnified all metal surfaces have microscopic peaks and troughs on their surfaces.
High pressures can create flash temperatures, heating metals and destroying regular oil.
Molecular attraction between the hot bare metals can cause surfaces to tear against each other causing wear and eventually the surfaces will weld together.
Bardahl’s exclusive ‘Polar Attraction’ formula cools metals, reduces friction and wear.
Unprotected metal surfaces are susceptible to excessive wear and tear. Morning start-ups and cold-starts with ordinary oils expose engines to potential break downs as these oils would have easily drained away from the critical moving parts when the ignition is turned off. The result could be potentially dangerous engine failures, which are expensive to repair.
Bardahl scientists successfully eliminated the problem of unprotected metal surfaces by carefully formulating a special additive known as “Polar Attraction”. Bardahl’s Polar Attraction formula electronically charges the molecules of ordinary oil and fastens themselves tightly to any oppositely charged metal molecule. In this way a microscopically thin, but extremely durable, film of lubrication is held magnetically in place against metal, insulating the surface against friction, heat and wear.
SynPulsar-M 5W-40 (Fully Synthetic Engine Oil)
Top tier fully synthetic engine oil specifically approved by DaimlerChrysler for use in Mercedes Benz’s engines.
Meets and exceeds many other industry and OEMs’ standards.
Viscosity consistency over a wide range of temperatures and operating conditions.
Exceptional protection against sludge, varnish deposits and frictional wear.
Recommended for use in modern gasoline and diesel engines of most passenger cars, light trucks, vans, SUVs and MPVs, including those with turbocharged engines.
Approvals / Credentials
API SM/CF
ACEA A3/B4-04
ACEA C3-04
BMW Long life – 04 (for 5W-30, 5W-40)
Porsche (5W-30, 5W-40)
VW 502.00/505.00 (5W-XX)
VW 505.01 (5W-30, 5W-40)
MB 229.51 (5W-XX)
MB 229.51 Approved (5W-40)
Pulsar-L 10W-40 (Premium quality Semin-synthetic Engine Oils)
Premium quality multi-grade motor oils formulated with advanced additive technology to provide maximum protection for all engine components.
Outstanding thermal and oxidation stability.
Ability to cope with the higher degradative stress in turbo charged gasoline engine cars.
Suitable over a wide range of operating conditions and temperatures.
Recommended for use in gasoline and diesel engines of most passenger cars, light trucks, vans, SUVs and MPVs, including those with turbocharged engines.
API SL/CF
ACEA A3/B3-04
VW 505.00
MB 229.1
Power-DI Plus 15W-40 (Super High Performance Semi-synthetic Engine Oil)
Top tier multigrade motor oil engineered for all types of diesel engines that surpassed some of the latest & highest engine oil performance specifications
Robust reserved alkalinity (TBN) for outstanding sludge control and acid neutralization
Excellent stay-in-grade stability ensure viscosity integrity and reduces oil consumption
Provides excellent soot control, easy cold weather start ups.
High viscosity wear protection under full load and speed operations
Superior oxidation and thermal stability for extended oil drain intervals.
Suitable for both diesel & gasoline engines, including EGR (Exhaust Gas Recirculation) engines.
API CI-4 Plus/CI-4/CH-4/CG- 4/CF-4/CF-2/CF/SL
ACEA A2-02, B3-98 / B4-02, E4/E6/E7-04
Cummins CES 20.071/6/8, 20.072/7
MB 228.3
Global DHD-1
Mack EO-M, EO-M Plus
MAN 3275
Renault VI RLD
Volvo VDS-2, VDS-3
ZIC LUBRICANTS
http://www.skzic.com/eng/product/content11.asp#
ZIC XQ 5W40 is a fully synthetic engine oil which provides total engine protection that meets and exceeds the toughest and latest standards of European, Japanese, Korea, and U.S. car builders.
ZIC XQ 5W40 combines fully synthetic base oil and state-of-the-art additives, which guarantee exceptional anti-wear protection and oxidation stability, coupled with excellent fuel economy performance.
ZIC XQ can be used in gasoline vehicles and light duty diesel vehicles such as pick-up trucks and SUVs without after treatment devices.
ZIC A+ is a 100% synthetic engine oil engineered to deliver outstanding engine protection and to offer improved fuel economy in vehicles where SAE 5W20 and 5W30 oils are recommended.
ZIC A+ 5W20 & 5W30 outperforms conventional oils and meets or exceeds warranty requirements for many Japanese and Korean car makers.
ZIC A+ 5W20 & 5W30 provides improved fuel saving benefits up to 2~5% compared to conventional motor oils of SAE 10W30 and delivers better performance.
APISN
ILSAC GF-5
Suitable to use in CNG/LPG engines
ZIC A is a synthetic engine oil coupled with the latest API SN grade, and is engineered with SK’s proprietary technology, VHVI TECH. ZIC A delivers exceptional fuel economy benefits and engine protection compared to conventional oil viscosity grades such as SAE 20W-50.
ZIC A is made of 100% YUBASE which enables it to provide outstanding fuel economy compared to conventional oil viscosity grades such as SAE 20W-40, or SAE 20W-50.
ZIC A has a longer draining interval compared to conventional oils, which enables you to extend your vehicle service interval. It also provides outstanding engine protection, and is recommended to be used in Japanese, Korean, American cars where API SN/SM/SL/SG is recommended.
API SN approval
ZIC HIFLO is a multipurpose premium grade engine oil of API SM, and it is designed to provide faster and cleaner engine protection to make sure of longer engine life.
ZIC HIFLO contains highly purified base oil and additives to meet API SM performance grade ensuring engines against deposit and wear problem.
ZIC HIFLO is applicable to Gasoline and CNG/LPG fueled engines.
Meets API SM performance
Meets or exceeds engine oil specifications of major engine manufacturers.
ZIC XQ 5000 15W40 offers outstanding wear protection and performance as well as longer drain intervals with its new API CJ-4 grade.
ZIC XQ 5000 15W40 meets and exceeds the toughest standard of European, Japanese, U.S, and Korean car builders, and is recommended for both conventional heavy duty diesel engines and modern heavy duty diesel engines which have after treatment devices such as DPF (Diesel Particulate Filter) or SCR (Selective Catalytic Reduction).
API CJ-4/SL, ACEA E9/E7
MB 228.3/228.31, RENAULT VI RLD-3, Mack EO-O Premium Plus, Volvo VDS-4,
CUMMINS CES 2008 1, MAN M 3275, Caterpillar ECF-3, DDC 93k218, MTU Type II
ZIC 5000 Power is a synthetic formula heavy duty diesel engine oil of API CI-4/SL performance, specifically engineered for longer draining intervals and better engine protection.
ZIC 5000 Power offers significant performance improvements over normal recommended specification.
ZIC 5000 Power guarantees better engine protection with excellent fuel economy.
ZIC 5000 Power maintains high viscosity index features enabling sufficient high viscosity for engine protection during engine operation and low viscosity for fuel economy at engine start-up.
Meets API service category CI-4/SL, ACEA E7/E5
Meets the latest engine oil specifications for major car manufacturers
ZIC SD5000 is a multi-purpose premium quality multi-grade engine oil of API CH-4/SJ performance, designed to provide excellent oxidation stability and engine protection.
ZIC SD5000 protects oil thickening caused by soot buildup, reduces engine deposits, and provides optimum bearing protection, resulting in increasing the life expectancy of your engine.
ZIC SD5000 is suitable for heavy duty diesel engines (including turbocharged) in both on/off highway applications.
Meets API service category CH-4/SJ.
Meets the engine oil specifications for major truck manufacturers.
ZIC RV series is engineered for high performing modern diesel engines and provides lower running cost in terms of fuel consumption as well as extended service intervals.
ZIC RV 10W-30 is specially formulated to suit modern common rail turbo direct injection diesel engines.
ZIC RV LS 5W-30 is a low-ash oil specifically designed for modern common rail diesel engines with after treatment devices such as diesel particulate filter (DPF/CPF) coupled with selective catalytic reduction (SCR).
API CI-4/SL (ZIC RV 10W-30), API SM/CF, ACEA C3 (ZIC RV LS 5W-30)
ZIC RV LS meets or exceeds European OEM specifications such as MB 229.51, BWM LL-04, VW 502/505.
Use for light duty diesel vehicles such as SUVs, CUVs, Pick-ups.
ZIC UP is a synthetic engine oil of supreme performance made of synthetic-like base oil with VHVI technology. ZIC UP is applicable to both light/heavy duty diesel and gasoline fueled engines and is especially designed for PICK-UP’s, VAN’s, SUV’s, MPV’s and 4WD off-roaders.
ZIC UP offers significant performance improvements over the latest recommended specification such as API CH-4, CF-4.
ZIC UP combines better engine protection with excellent fuel economy.
Its wide viscosity range provides outstanding protection consistent with SAE 40 grade oil at high temperatures, combined with the easy cold-start performance of a 10W rated oil.
Meets API service category CI-4/SL and MB 228.3/229.1 performances.
Meets ACEA A3/B3/B4.
For inquires call or text
0922-887-2079
http://www.yubase.com/ (base oil of ZIC) largest refinery and supplier of base oil in korea...
SynPulsar-M 5w40 (449/liter) Fully Synthetic
SynPulsar-M 5w50 (499/liter) Fully Synthetic
Pulsar-L 10w40 (219/liter) Hi-grade mineral based
Power-DI Plus 15w40 (299/liter) Semi synthetic heavy duty
ZIC XQ 5W40 (659/liter) Fully Synthetic
ZIC A PLUS 5w30 (599/liter) Fully Synthetic
ZIC A 10w40 (299/liter) Semi Synthetic
ZIC HIFLO 20w50 (279/ liter) Semi Synthetic
ZIC XQ 5000 15w40 (679/ liter) Fully Synthetic
ZIC RV 10w30 (349/liter) Fully Synthetic
ZIC UP 10w40 (299/liter) Semi Synthetic
ZIC SD5000 (269/liter) Semi Synthetic
for inquiries call 0922-887-2079
