Forget everything you have seen or heard about the new Dodge Challenger SRT Demon. It’s all just fluff compared with what we are exclusively about to tell you here. This car isn’t just a warmed-over Hellcat, it’s a completely new standalone model which will shatter any thoughts you have about what a muscle car can do.
Don’t believe us? Try these for size. The new 2018 Dodge Demon is/has all of the following:
The world’s fastest production vehicle 0-60mph/97kph time. Posting a satanically fast time of just 2.3 seconds, it is faster than a Bugatti Chiron (2.4 seconds) and the Tesla P100D with Ludicrous Plus (2.3 and a little bit). And that’s with the Demon being rear-wheel drive only compared with those two cars’ all-wheel drive platforms.
The world’s fastest-ever production car over the quarter mile. Ready for this time? The Dodge Demon trips the lights at an insanely fast 9.65 seconds and on to a top speed of 225kph. You want a comparo? The latest ultracars from McLaren, Porsche and Ferrari can manage ‘only’ 9.8 seconds. The Chiron might ultimately beat it when it finally appears. But for now the Demon is the king of the quarter mile.
The highest production car acceleration G-force. You can’t achieve the above feats without some physics happening. And the Demon is no different. Consider for a second how 1.8G of acceleration in the Demon feels like. Yeah, exactly.
The world’s first production car to fully lift its front wheels while accelerating. Yes, you read that right: the Demon pulls wheelies. And that’s not just Dodge’s claim—it brought along the folks from the Guinness World Records to verify it, which they did.
Been banned by the National Hot Rod Association (NHRA) from any of its member tracks. Quite simply, for being too fast.
As mind-blowing as that little lot might be, it’s still a very long way from the end of the Demon story. But the big question is how Dodge managed to wring quite so much performance out of what is essentially a Challenger. The answer is: 97 new parts, the deletion of a several key components, and some serious light-weighting.
Let’s start with the heart of the matter: the engine. Despite the fact that they are both supercharged V8s, the only similarity between the Hellcat’s and the Demon’s powerplants are the heads. Everything else on the Demon is new. And it needs to be as it’s carrying a lot more load.
While the Hellcat peaks at 707hp and 881Nm at 4,000rpm, the Demon produces 808hp and 972Nm. That’s a useful increase but still doesn’t explain those performance numbers. So this is a good time to tell you about the Demon race kit, which will be available for each of the 3,000 or so Demons that go down the production line.
When you buy your car, you will be given a coupon. Don’t throw this away. The coupon entitles you to buy the Demon race kit for the princely sum of $1. This kit, which comes in its own bespoke crate, contains everything you need to turn your road Demon into a track Demon.
Among other things including a pair of smaller, lighter front wheels—as standard the car wears 315 section Nitto NT05R drag radials all round (another world first), effectively two sets of rears—plus a jack and an impact driver, the kit contains a controller which screws into the center console. When fitted, this controller allows you to magically run your Demon on 100-octane race fuel, just by pressing a button.
The car measures the gasoline's octane and, if it hits 100, resets all of the engine’s timing to make the most of it. In this beast mode, the Demon produces 840hp and 1,044Nm. And it keeps making that power almost irrespective of what the weather is doing thanks to an intake chiller system that actively sucks heat out of the engine and supercharger coolant.
The colder the air, the more dense it is, the more dense the air, the more you can pack into the cylinders. More air equals a bigger bang, which equals more power. Fulfilling the ‘more air’ part of the equation are a pair—instead of the Hellcat’s single Air Catcher—of grille-mounted air intakes as per the Challenger T/A concept. Plus a vast hood-mounted air scoop—the biggest on any production car in the world, naturally.
All of which would be less effective if the Demon hadn’t lost some of the Hellcat’s weight. Which it has—it tips the scales a full 90.7kg less than its little brother.
To save weight it comes as standard with just one seat, the driver’s. If you want the passenger seat you can have it added in for just $1. And if you insist on the rear seat, that’ll cost you, yes, another $1. Other weight-loss measures include a new steering rack, smaller brakes, less NVH deadening material, lighter wheels, stereo, no spare wheel, and a few other odds and ends that you really won’t notice. Because you’ll be having far too much fun launching this thing off the line.
To the Demon’s list of world firsts for a production car you also have to add: the fitment of a transbrake. This drag racer staple—mounted as a paddle on the steering wheel here—effectively locks the gearbox so you can preload the drivetrain without the car pushing forward, as can happen when you have road roller-sized rears and skinny fronts.
With this engaged and the throttle mashed, you just stage up, wait for the green then ping off the transbrake and away you go, wheelie-ing off into the distance as 719Nm and 8lb of boost hit immediately. Making sure you make it to the end of the strip, downstream of the gearbox and transbrake are a massively stronger drive shaft and lower 3.09 rear gears instead of the Hellcat’s 2.62. So it’s been built to handle all the extra stresses.
But don’t think the Demon is a straight-line only car. Far from it. Using adjustable dampers—which loosen the front and firm the rear when in launch mode—the Demon can handle spirited road driving just as well— if not better—than any other Challenger.
Top speed is limited to 270kph due to the drag radials, so it loses a little top end. But it registered the highest lateral G loads of any Challenger ever tested during the cornering tests. And it brakes faster from 100kph to zero than a Viper ACR. So don’t underestimate it anywhere.
There are thousands more Demon details and stories we can dig into later. But the burning question right now is: when are we going to get to drive it?  Dodge is saying sometime around July.
We have the whole month blocked out already…
Pat Devereux
Dodge Dodge Demon drag race muscle cars performance cars
