SHARE:
First, there was LaFerrari, and it was good. Then came the LaFerrari-based FXX K, and it was wild. Now, just when you thought it was safe to go back into the water comes the deranged LaFerrari-based FXX K Evo.
Time perhaps, to ponder whatever life choices have led you to the point where you can't drive one of these things, because Ferrari is promising significant advantages over the already bombastic FXX K. Chief among which stands the car's improved downforce.
The FXX K Evo boasts 23% more downforce over the FXX K, and an even more astonishing 75% more downforce than LaFerrari. Is your brain even able to process that much additional downforce? We're talking 640kg at 200kph, and 830kg at the "car's redline speed." Maybe just imagine the noise of an FXX K Evo attempting to produce max downforce…
As with any self-respecting Evo, it's all in the detail. And, if you're not up to speed on wake and hot air flow, then apologies—it gets a bit technical from here on in. The FXX K Evo gets a twin-profile fixed wing, designed to work in tandem with the active rear spoiler; indeed, the active spoiler's control "logics" were reprofiled, too.
That fixed rear wing also gets a pair of side fins and one central fin, the latter able to create more stability at "low yaw angles," and support the vortex generators (fins, to you and I). These little vanes help clean the air hitting the wing; specifically, the hot air flow created by those radiator hood vents. They also create 'downwash,' which isn't what you originally think it means—it boosts the rear wing's downforce capacity.
The rear wheel arch vents have been enlarged, too, in line with the reprofiled rear wing, to more effectively channel the wake from the rear wheels. Considering the FXX K’s V12 boasts 1,036hp sent to these wheels, there is much wake.
And a different back means a different front. The bits between the front headlights were hollowed out, allowing for a couple of 'flicks' and an extra air intake ahead of the front wheels. Oh, and additional vortex generators on the undertray made necessary by the changes to the front and rear. What you end up with is a whole lot of air being muscled and bullied into whatever form the FXX K Evo sees fit.
Suspension? Recalibrated for additional downforce. Cabin? A new steering wheel and larger 6.5-inch rear video screen with telemetry. Engine? Nuts. Though it's the same 1,036hp V12 as the FXX K, you only need a cursory listen to ascertain it might not be from this universe.
Ferrari tells us this FXX K Evo will be available in a limited run (no number is given but expect only a handful), or as an upgrade pack for FXX K owners. And as with all of these XX cars, you can't run them on the road.
"Mirroring the vocation of its predecessor," Ferrari explains, "[the FXX K Evo] is aimed at a small, highly select group of Ferrari clients: supercar enthusiasts eager to share the development of technologically innovative content with the Prancing Horse technicians, through driving a closed-wheel laboratory car."
That's right, driving a Ferrari FXX K Evo isn't driving a deliriously overpowered slice of unobtanium, you are doing science. So, about those life choices…
SHARE:
Vijay Pattni
supercars Ferrari Ferrari FXX Ferrari FXX K Ferrari FXX K Evo Italian cars Premium News
