As the only and biggest Filipino refiner, Petron has a deep understanding of the unique driving conditions on Philippine roads, and it takes pride in formulating products that will deliver optimum efficiency for Filipino motorists.
Engine oils are essential to ensure efficient operation of gasoline and diesel engines. They have two primary functions: to minimize friction and to prevent wear on the moving parts of engines. In addition, engine oils also act as a coolant, protect metal parts from corrosion, and prevent formation of engine deposits.
While all engine oils perform basically the same function, how well a particular product does is determined by its quality, notably the components that go into the oil blend. Petron engine oils, which are specially formulated to enhance the performance of all types of engines based on local conditions, have been subjected to international laboratory testing to meet world-class benchmarks.
Petron Ultron Gasoline Engine Oils contain the Thermal Stress Stabilizing System (TS3) that keeps the oil stable even at extreme temperatures, providing ultimate protection from engine stress while maintaining superior engine cleanliness. Petron Ultron oils have undergone widely-accepted international engine tests to demonstrate their excellent performance on engine stress protection, engine cleanliness and thermal stability.
Based on an actual test on a Porsche 997 engine, Petron Ultron provided effective protection against wear. It also delivered excellent control on sludge and varnish formation in an actual Sequence VG test. Its ability to provide superior engine cleanliness was proven when it was tested on a Volkswagen T4 engine. Viscosity tests also showed that Petron Ultron Oils are stable at both low and high operating temperatures.
Complementing Petron Ultron is a range of Petron TriAction Advantage gasoline fuels that give better engine protection, better mileage, and better power, such as: Petron Blaze 100 that meets European quality standards; Petron XCS with complete combustion system; and Petron Xtra Advance to help you go the extra mile.
Petron REV-X Diesel Engine Oils are formulated with Dynamic Cleaning Technology (DC Tech), which provides excellent engine cleanliness and engine protection for long drain performance and longer engine life. It meets and exceeds the stringent requirements of international engine tests designed for diesel-fed vehicles. Petron REV-X engine oils were tested for engine cleanliness and engine protection. An actual Volvo VDS-2 eld test was also conducted to demonstrate the longer and extended drain performance of Petron REV-X engine oils.
To get the most out of your diesel engine, use only Petron’s hi-tech Euro-4 diesel fuels: Petron Turbo Diesel for high performance vehicles, and Petron Diesel Max for improved fuel economy and reduced emissions.
Petron Sprint 4T Motorcycle Oils are designed to meet the unique performance requirements of four-stroke motorcycles. Unlike passenger cars, motorcycle engines require lower oil volume, have higher power output, and operate at higher engine speeds. Petron Sprint 4T oils are formulated with Thermal Control System (TCS) to enhance the oil’s thermal and oxidation stability, which are critical for motorcycle engines due to their unique operational requirements.
All Petron engine oils are offered in different viscosity grades and quality levels to cater to all types of engines operating under various conditions. What makes Petron engine oils stand out are the unique formulations that have been designed by Filipino engineers who best understand the needs and requirements of the local market.
Petron knows you deserve only the best fuel and engine oil for your driving requirements.
