The Grassi Scuderia Milanese 044S is a glorious Lancia Delta S4 tribute
If Group B rally lived on...
Grassi Scuderia Milanese 044S tribute to Lancia Delta S4
PHOTO: Grassi Scuderia Milanese
It has been designed, according to its Italian makers, to marry high-performance supercar smarts with everyday practicality. Which is fine of course, assuming your everyday practicality involves blasting across rally stages.
Welcome, one and all, to Grassi Scuderia Milanese’s very first offering – the 044S. Penned by former Alfa Romeo designer Giuseppe Armano, the car is said to recreate the “lines and distinctive elements typical of the iconic cars that have made the history of the World Rally Championship Group B”.
Hyundai Ioniq 6 PH prices announced, and it starts under P4-M
This Ford Transit is the wild, 1,400hp electric Supervan 4.2
(A history fraught with as much danger as it was speed, you’ll know. Following a number of accidents and deaths across multiple seasons, the FIA ended up banning Group B cars deeming them too fast to compete safely.)
The 044S’s drivetrain is typical of those Eighties technological marvels. There’s a socking great 3.0-liter biturbo inline four-cylinder petrol engine underneath that boxy hood, dry-sumped and producing 650hp. That’s matched to either a sequential six-speed gearbox or six-speed manual, but both send power to a permanent four-wheel-drive system bearing three differentials. There’s a “range of cutting edge technologies” on board to deploy that power safely, too.
And quickly, because with a weight of just 1,200kg (1,100kg dry) via liberal use of carbon fibre and aluminium in its construction, the 044S is able to hit 62mph from rest in just 2.9s and crack on to a top speed of 300kph. We’re promised the Group B hat tip “will be surprisingly agile and maneuverable”, which is no surprise when you consider 650hp x 4WD x featherweight body.
There are ventilated discs front and rear wearing six-pot calipers up front and four-pots on the rear to slow the thing down quickly, hiding behind 19in staggered alloys. If you’re struggling to size it, think roughly Toyota Raize in length (4.0m), but a whole lot wider and lower than the popular crossover. Punchy, no?
Ditto the looks. Clearly recalling Lancias Integrale and Delta S4, the wild body has been honed for aerodynamic efficiency; as though Eighties designers were tasked with imagining an S4 of the future.
Just 44 will be made, though prices haven’t been revealed. GSM has revealed each car will be entirely customisable, so maybe option in some boot straps to tie down your shopping, perhaps?
Note: This story first appeared on TopGear.com. Minor edits have been made
