What to do when you damage your license plates
Better safe than sorry
PHOTO: Department of Transportation
Your license plate is more than just a piece of identification for your ride. It is a legally mandated requirement for using a vehicle on Philippine roads. As we drive around the metro, you will always see at least one of those “temporary plates” or “lost plates” attached to vehicles. But is this proper? What exactly do you do when you have a lost or damaged plate? We've prepared this guide to help you figure out the steps.
First of all, driving without a license plate is illegal; it may result in fines and your car might even be impounded if you are caught without them. If you’ve damaged your plate and/or lost it, the first thing you will need to do is to prepare an affidavit of loss or mutilation. This document can be prepared by your local notary public.
You will then need to go to the LTO office where the vehicle was last registered, then you’ll be asked to present these documents to substantiate your claim:
Documentary requirements to report lost or damaged license plate:
  1. Notarized affidavit of loss or mutilation
  2. Certified true copy/original certificate registration
  3. Certified true copy/original of the latest official receipt for the motor vehicle user’s charge and other fees
  4. In case of for-hire motor vehicles, certification from the LTFRB that the plates have not been surrendered
  5. In case the vehicle is under a company name, the secretary’s or DTI certificate
  6. PNP-Highway Patrol Group clearance
Once the LTO has been informed that the plates are lost or damaged, you will be directed to the transaction counter to submit all the required documents to the evaluator for evaluation and computation of fees.
This is the LTO’s new rules for temporary and improvised plates in PH
5 things you need if you lost your LTO OR CR of your motorcycle
The LTO will then inspect your vehicle and issue an accomplished and approved Motor Vehicle Inspection Report (MVIR). This form can also be completed prior to going to the LTO should you wish to expedite the process.
Once this is done, proceed to the cashier to pay the necessary fees and obtain an official receipt/proof of payment for the cost of replacement/duplicate plate.
You will then be sent to the releasing counter to obtain the necessary certificate of registration, plates, stickers or other requested documents. This should also include authorization by the LTO to use improvised plates that are usually valid for 90 days, but this is to be taken with a grain of salt, as it can depend on the LTO office handling your request.
So there you go. It may sound like a bureaucratic nightmare, but trust us, the hassle of the system is nothing compared to the hassle of being caught on the road without any plates. At the end of the day, our beloved cars’ license plates are intrinsic and essential to our right to traverse the roads with our vehicles. The state has all the right to prevent you from using your vehicle without the proper regulatory safeguards for public welfare. Take good care of your plates and treat these instructions as a last resort.
