Motorcycle Feature
Specs, prices, features: Everything you need to know about the 2024 Yamaha PG-1
Yamaha’s newest offering is finally here
photo of the Yamaha PG-1 2024 off-road
PHOTO: Sharleen Banzon
In case you hadn’t seen it yet, Yamaha Motor Philippines (YMPH) just launched the all-new Yamaha PG-1, arguably the brand’s most anticipated model of the year yet.
We were actually able to take it out for a quick spin recently. If you want to read what we think, click here. If you want to learn more about Yamaha’s newest offering, then scroll on further below.
5 (confirmed) things to know about the 2024 Kia Sonet
Yamaha PH launches the new Sniper 155: Here are the specs, prices, and features
Pricing
photo of the yamaha pg-1 2024
Only one variant of the PG-1 and—at least for now—a single color option is available in the Philippines. This new bike stickers for P96,400.
Design and dimensions
The PG-1 measures 1,980mm long, 805mm wide, and 1,050mm tall. It has a 1,280mm wheelbase and has a seat height of 795mm or 31.29 inches. Minimum ground clearance is listed at 190mm, and curb weight is at 107kg. It has a 5.1-liter fuel tank.
This little bike sits on 16-inch front and rear wheels, both of which are shod in 90/100-16 M/C 51P tube-type knobby tires.
Engine and specs
Powering the PG-1 is a 114cc air-cooled, single-cylinder engine that puts out 8.88hp at 7,000rpm and 9.5Nm at 5,500rpm. This is mated to a four-speed semi-automatic transmission.
Stopping power is handled by a single disc brake up front and drum brakes at the rear. The suspension setup consists of a telescopic front fork and a swingarm out back.
Extra features
This is a pretty bare-bones bike, so it doesn’t get a lot of creature comforts. There’s no ABS or electronic safety bits here, so don’t expect to get those. It also gets an analog instrument cluster with a speedometer, a fuel gauge, and a gear indicator.
The PG-1 also gets a pillion seat and a grab bar out back as standard, as well as a tiny underseat compartment that can hold, at the very least, your motorcycle’s registration documents. It also has an upward-pointing exhaust pipe, making it slightly more capable of going off-road, or even crossing shallow waters.
What do you think of the new Yamaha PG-1? You can check out more photos of it below.
More photos of the Yamaha PG-1 2024:
