The F1-inspired, 800hp Quantum GP700 was built by ‘just a bloke in a shed’
And yet it’s faster than a Merc-AMG GT R Pro around an Australian circuit
Action shot of the Quantum GP700 driven by its creator Jeff David
PHOTO: Toby Thyer
I point to a graffiti-covered bus stop in a layby, signaling to stop for a quick photo. That’s the excuse, anyway. In truth, I need a moment to stand on solid ground. After riding shotgun with Jeff, my head feels like I’ve just been bench pressing 160kg with my neck. Then again, 1.2g under acceleration will do that.
The numbers behind the Quantum GP700 are impressive: 800hp, 748kg (wet), 0–160kph in 4.4sec. Top speed remains untested, though it’s geared for 310kph. FastestLaps.com shows a 1:25.60 lap time around Winton National Circuit—nearly 4sec faster than a Merc-AMG GT R Pro.
Image of the Quantum GP700 with its creator Jeff David
Image of a kangaroo
I meet Jeff David at his Gisborne property in the Australian state of Victoria to figure out how something this extreme could emerge from a backyard workshop without commercial backing. He insists he’s “just a bloke in a shed,” but most blokes aren’t using a digger to simulate downforce on their homemade, F1-inspired hypercar.
Opinion: All the hate on the Luce was Ferrari’s fault alone
F1 races will have fewer laps in 2027...because the cars’ fuel tanks aren’t big enough
Jeff’s story starts with bikes. He spent years as a KTM team rider and has a wall of trophies to prove it. So why not stick with motorcycles? “I was getting too old for dirt bikes, and fast road bikes are just too dangerous,” he says.
“The only place you can use that kind of speed safely is on a circuit. I wanted something like an Atom after seeing Clarkson on Top Gear. It just made sense. Fast, but usable.”
He imported an Ariel Atom in 2005, but even after the painful process of getting it road-legalized, it proved unsatisfactory on public roads. He started pulling it to pieces and reworking every single part. At one point, he even sent pushrods to a mate at McLaren for fitting strain gauges. It turned out that when all 400hp was unleashed, only 15kg was being carried by each front wheel. That’s not a great recipe for handling.
Rear view of the Quantum GP700
Armed with data from MoTeC systems and simulation tools like Bosch’s motorsport suspension software, Jeff made a bold decision: He cut into the Atom’s chassis and extended the frame by 12cm. “It instantly improved handling,” he says, “but it was never going to be a 2g car as it lacked aero. I decided to build my own, using what I had learned and starting with a blank sheet of paper. But its concepts were based on F1 and F2 of that era.”
His background in dirt bikes became the foundation for the GP700. “I tuned suspension for bikes that won their class at Finke,” he explains, referring to Australia’s brutal desert endurance race. “Eventually, I was tuning bikes regularly on my dyno.” That hands-on approach evolved into a deep understanding of everything, from combustion-chamber design to suspension witchcraft.
Image of Jeff David, creator of the Quantum GP700
“Compared to bike suspension, road-car suspension is prehistoric,” he says. “The systems I use date back to 1998.” Jeff logged suspension data from one of his best-performing bikes, translated it into spreadsheets, and built a kinematic model in a 3D CAD software called SolidWorks: “That let me apply 40 years of bike suspension development directly to the car.”
The engine is an imaginative mongrel based on Honda’s K-series—a CR-V block teamed with a Type R head and an S2000 F22C crank. But beyond the base castings, everything is custom. Sleeves, rods, pistons, cams, porting, manifolds—the lot.
“About 30% of my effort has gone into developing the K-series,” Jeff says, lovingly describing his bespoke internals. “Piston crowns were shaped by hand, porting optimized and tested on the dyno until I got the results I wanted. They eventually became off-the-shelf products—without asking me,” he adds. He also sent a hand-ported cylinder head to 4Piston Racing, who sent back two CNC-ported heads in return.
Cockpit of the Quantum GP700
The gearbox is equally bespoke, a six-speed, air-shifted Holinger unit. “They used CAD data from my rear chassis to design a custom gearbox,” Jeff explains. “I couldn’t afford the rights, so they kept it—and it ended up as OEM equipment on the KTM X-Bow.” It’s coping with two times its rated torque.
When he committed to building a new chassis from scratch, weight and strength were the priorities. It also needed to meet Victoria’s strict road registration standards. To accelerate development, Jeff enlisted 11 university students completing their final-year theses. “I was the industry supervisor and had three students focused on the chassis—CAD, torsional rigidity, all of it,” he says.
Testing was all done in his shed. “I bolted the rear of the chassis to the concrete slab, attached a pipe to the middle, hung a cement bag off it—because I’m old-school—and measured deflection with a steel ruler,” he laughs. “Between that and the CAD work, we nailed it.”
Component of the Quantum GP700
Insights from cracking aluminum dirt bike frames informed the design, resulting in a lightweight yet immensely strong structure. The rear cross member, cut with a high-pressure water jet, weighs just 2.5kg but can handle 800hp.
Alignment was also carefully considered: “I didn’t want it to be difficult to build straight,” Jeff says. “The nose section dovetails together, so as long as the jig is accurate, suspension alignment is accurate to within half a millimeter.” The bodywork keeps a hands-on approach. “I knew it needed a Formula 1-style front wing and nose,” he says.
The design went from Jeff’s imagination into Maya [3D modeling software], and with help from his son Andrew, he refined the surfaces. Foam blocks were CNC-routed, layered with raw carbon fiber, and finished by a body shop. “I’ve still got the moulds upstairs,” he quips.
Front end of the Quantum GP700
Electronics tie everything together—before all this, Jeff worked as an electrical engineer for Honeywell, a kind of Winston Wolfe for critical systems across industries from oil rigs to airports, and it’s clear he’s well versed in speaking technically. “Some calculations happen in Emtron, some in MoTeC, and they share data, much like a computer network,” he explains. “Many sensors are off the shelf, but the data analysis has been customized over decades of refinement.” Yes. Good. And it’s painted red, you say?
The big question then: Where can we buy one? “I had potential investors,” Jeff says, “but it all fell through. It would cost too much to build them here.” It’s a bittersweet conclusion. The Quantum GP700 is a masterpiece of engineering, born from decades of experience, ingenuity, and persistence—all inside a shed by a bloke with a vision as wide as Australia itself.
If this is where the story ends, it feels like a loss. But for now, the GP700 exists as proof of what one bloke in a shed can achieve with passion, know-how, and a very patient wife.
Quantum GP700 on public roads in Australia
PHOTO: Toby Thyer
