Maintenance tips: Honda BR-V
All you need to know about this model, plus how to keep it running strong
PHOTO: Top Gear PH
For the past few years, Honda’s rash of crossovers and MPVs is bringing new customers through the doors in droves. The Asian-market BR-V, in particular, presents a unique attack on the subcompact-crossover market.
Exterior
At first blush, the BR-V looks remarkably like the Mobilio it is based on, down to the stepped beltline, albeit with extra black side cladding. But a slightly longer wheelbase, a 210mm ride height, fatter tires, and sexier styling make all the difference in the world to crossover-crazy buyers.
Interior
Seated behind the wheel, you appreciate the work that has gone into differentiating the BR-V from the Mobilio. Aside from the cheap-looking (but effective) ceiling vents, the interior looks much like that of the higher-class City.
Driving impressions
Indeed, the BR-V drives much like the Honda sedan, with the same light touch, effortless CVT, and confident body control. Unfortunately, the low seat point and the lack of height adjustment leave you wondering if this isn’t indeed a City in disguise. Avanza drivers literally look down upon you as you pass each other on the street.
Thankfully, Honda isn’t kidding about that ground clearance. The BR-V takes in stride tall humps and steep parking ramps that would catch out a sedan. Despite the ride height, the revised dampers and suspension vis-a-vis the Mobilio give it a lot of mechanical grip. The only dings on its backroads performance are the grabby rear drum brakes (capable, but hard to modulate) and the lack of rear suspension travel—odd for a car with this much ground clearance.
Yes, crossover-ish aspirations notwithstanding, the BR-V is clearly not meant to go far beyond your typical half-developed farm road. But for the daily grind, it’s perfect. The narrow width and good sightlines ensure that threading through traffic is a breeze.
Engine and performance
Both S and V variants come with the 1.5-liter engine and the CVT from the City, with Sport and Low modes to make up for the lack of paddle shifters. Despite the heavier body, both deal with even the steepest of climbs with no issue. The most you could ask for is a little more engine braking from the CVT in Low mode for hill descents.
While lacking the HR-V’s pull in high revs, even in Sport mode, the BR-V feels just as quick through traffic, and pips the HR-V by about 1km/L in urban economy. On the highway and with a full load, it returns an impressive 20- 22km/L at 80kph.
The first iteration of the BR-V listed prices starting under P1 million. It offers a lot of space, utility and style for the money, even for the newer models. Not surprising, then, that buyers just can’t get enough of it. (Dinzo Tabamo)
Recommended maintenance schedule
Most modern cars are very reliable these days, with some being more idiot-proof than others. A fellow enthusiast likes to call such cars as “gas n’ go.” You put gas in the car, and you go. No doubts about whether the car will start the first time. No fears that a warning light will suddenly pop up. The ideal daily driver is essentially an appliance that you can use for many years until you get tired of the look or it finally falls to pieces (unlikely). If you follow the maintenance schedule, and if you have a basic sense of car maintenance, you can reasonably expect your car to run perfectly fine for many, many miles. Here are 10 quick tips to keep your ride in tip-top shape:
1) Check the fluids every week.
Coolant, water reservoir, oil, brake fluid, power steering, automatic transmission fluid (if applicable), and the windshield washer. There should be no significant loss in any of these except the washer fluid on a week-to-week basis. If there is (for example, from full a week ago to half-full), this could indicate a leak somewhere.
Check the ground underneath the car for any telltale leaks or puddles and trace the origin (a few drops of condensation from the A/C system is normal, though). If everything’s good, you should only need to top up the washer fluid and water reservoir.
2) Follow the 5,000-7,500km maintenance schedule.
Depending on your car’s make and model, the service interval is important to your car’s wellbeing. The primary service is the oil and filter change, but this may also include several other services such as cleaning the A/C filter, recharging the freon, and changing the transmission fluid, and any other fluids and filters. Spark plugs are also replaced every year.
3) Check tire pressure every week.
Tires gradually lose tire pressure after several days, but they also gain a few psi as road and tire temperature increase. These have a recommended tire pressure, taking into account your average passenger and cargo load. You’d do well to follow these guidelines (it’s usually printed on the driver’s side door panel), but one or two psi above/below the recommended won’t hurt the car and will let you tailor the ride quality to your preference.
If one full tank of gas lasts you a week, get the tire pressure checked right after you gas up, preferably while your tires are still cold in the morning. Watch out for noticeably soft tires (say, 5-10 psi below the usual), indicating a slow leak somewhere. Inspect the tire but don’t pull out the foreign object, which is usually a nail or bolt. The tire will quickly deflate if you do, and you don’t want to ruin it by running flat. Bring it to a vulcanizing shop so they can patch it up and save the tire.
4) Mind the tire rotation, alignment, and balance.
Have your tires rotated every six months or 10,000km to maintain even tread wear. When you do this, that’s when you’ll need to have them balanced and/or aligned.
5) Find out if you really need to have it rust-proofed.
Some casas may try to sell you on a four-figure “paint protection” service. Unless you park right by the sea or live in a snowy climate, you don’t need this. The shell of the car already has several layers of primer and paint to protect the metal from rust.
6) Check your battery.
Depending on your usage, the battery will last anywhere from a year to two. A telltale sign that the battery is about to die is hesitation to turn over on startup. When in doubt, bring it over to a battery shop so they can check it for you.
7) Do not ignore your timing belt/chain.
This is probably the most critical item in your service manual that you don’t ever want to ignore. When this breaks, your engine will freeze and you’ll be stuck with an overhaul. The recommended replacement schedule is somewhere between 60,000-70,000km, depending on the car.
8) Know when you need a transmission overhaul/clutch replacement.
“Overhaul” is a scary word, but it’s just a routine service if you’re talking about the transmission. When your car’s gears begin to slip or refuse to engage, that’s a sign that the clutch is worn out and needs replacement. Don’t ever let a service advisor tell you that the entire transmission needs to be replaced, especially if it’s less than 100,000km old!
9) Know if you really need 95- or 98-octane gasoline.
Not really, but it helps. Unless it’s a luxury/sports car, most daily driver gasoline engines do okay with regular unleaded (93-octane), but some run better with higher grade gasoline. However, if you have a minor engine mod like an aftermarket ECU chip, some knocking may occur with 93 Octane (especially during the summer when temperatures are higher). In that case, spending several hundred pesos more for 98-octane will result in smoother operation and peace of mind.
10) Have the Italian tune-up.
Metro Manila traffic is hell on an automobile and qualifies as “extreme road conditions” because of the incessant stop-and-go that’s hard on the transmission, and the fumes ingested by the air intake. Once a week, or at least once a month, take your car to a longer drive where you can gently work the upper ranges of the gears and blow out any crud from the pipes. (Andy Leuterio)
PHOTO: Top Gear PH
