10 Things you need to know about the Nissan GT-R
#1: Not all Skylines are GT-Rs, and not all GT-Rs are Skylines
1. Not all Skylines are GT-Rs, and not all GT-Rs are Skylines. Wait, what?
Okay, so this can get complicated if you’re not into your GT-R-slash-old-JDM metal, but bear with us. The Skyline was a regular little sedan or wagon produced by the Prince Motor Company from the late ’50s, then absorbed into the Datsun (and latterly Nissan) portfolio—along with the company itself—in 1966. And the name has survived without having any connection with GT-R-ness. So there are plenty of weird vintage Skylines out there that have absolutely nothing to do with either: a) the Fast and Furious franchise; or, b) going fast. Simply announcing ‘I’ve got a Skyline’ could mean a variety of unmentionables.
In fact, the Skyline name had some really interesting and lesser-known iterations without GT-R bits (look up the R30 and R31), and some base models that will sap your will to live just by looking at them. Though a DR30 RS Turbo R30 is probably something of a guilty pleasure. And that’s without mentioning the US-market Infiniti Skylines.
There are plenty of Nissan Skylines that aren’t GT-Rs, but are sort-of associated, which is where it all goes a bit Scrabble-championship with GTt, GTSr, and GTs-25t. The GT-R legend only really got going with the debut of the PGC-10 Skyline GT-R in 1969 (2.0-liter, 160hp, 180Nm, RWD), and it actually appeared first as a four-door, with 1971 seeing the sexier coupe.
Got that? Well, it changed again with the R35 in 2007, because the GT-R stopped being a Skyline and just became a GT-R. Yeah, kind of confusing really.
Pictured: 1982 Skyline H/T 2000 RS
2. The R33 is the least-favored of the GT-Rs.
Bigger and heavier than the R32, it supposedly had exactly the same engine and power (power outputs were always a little underplayed in GT-R land), but appeared a bit more portly, so it’s slightly flown under the radar. The R34 looked more aggressive, the R32 looked more svelte, and the ‘classic’ GT-Rs looked, well, more classic.
Starting to seem a bit more attractive now that just over 1,600kg doesn’t seem all that monstrous, the R33 will get very popular when people notice that under the USA’s NHTSA 25-year time-out classic import regulations, our American brethren will be able to import them for the first time in 2020. Time for a quick trawl of used R33s? Yep. And if you can find a cheap, unmolested Nismo 400R, you’ll be on to a winner. Mind you, you’ll be more likely to find a winning lottery ticket stapled to your own forehead.
3. You can’t call all GT-Rs ‘Godzilla.’
It might be popular to refer to all GT-Rs as ‘Godzilla,’ but in reality, the nickname only really refers to R32s. Why? Well, Oz was the first place that Nissan exported the R32 GT-R to, and in the early ’90s, it smashed the Australian Touring Car Championship (Group A) to bits, winning pretty much everything it entered from 1989 to 1993, and knocking the Sierra Cosworth off its pedestal.
The Australian motoring press (god bless ’em), referred to the R32 as Godzilla because it was a ‘monster from Japan,’ and elicited a Wheels Magazine cover that featured a red R32 GT-R with the memorable headline: “Nissan’s new Godzilla on wheels aims to slay the Sierra. And it’s here soon.” So you can’t actually refer to any other GT-R as ‘Godzilla’ without referencing the origin of the name with the R32 race car. Or GT-R buffs get all clammy and go a bit red.
4. Say what you like, but Attesa is just weird.
Attesa (Advanced Total Traction Engineering System for All-Terrain) is the GT-R’s four-wheel-drive system originally debuted in the Bluebird way back in 1987. But the E-TS (electronic torque split) variant seen in the R35 is one of those systems that just seems fiendishly, outrageously complicated, so much so that engineers can’t really work out why it’s so effective—it just is. It’s a front-engined, rear-transaxle that looks like a RWD car, until you notice the secondary driveshaft that transfers power back to the front wheels.
Torque can be split 2:98 front to back, say, during a launch, up to a maximum of 50:50, and there are a myriad of yaw sensors, accelerometers, and a three-axis G-sensor that mean the GT-R can pitch traction front to back and side to side depending on conditions. GT-Rs in general are set up to feel rear-biased in most situations, with a healthy dose of get-out-of-jail-free front-axle intervention when you inevitably overcook it. Add into that HICAS four-wheel steer, and things get complicated—though lots of owners lock out the HICAS and disable the front axle on older models to make them more, uh, exciting.
5. The R35 GT-R is lopsided.
With reference to the previous mention of Attesa on the R35, if you look underneath one (and detach all the carbon under-trays), you’ll notice that the front right axle is actually shorter than the left, because the diff itself is closer to the right-hand wheel and the front left axle runs through the sump of the engine to get to the other side.
Add to that the secondary driveshaft (powering the front wheels) that sits to the right of the ‘main’ central driveshaft, and you’ve got a car that looks very asymmetrical from below, even though weight distribution is 53/47 front to rear, and it doesn’t corner better one way or the other. Obviously.
6. The special-editions thing got a little bit out of hand.
Yeah, well, marketing. And a very tunable package. But the GT-R didn’t half get through some ‘specials’ during some of the phases of its life, and that’s not counting the thousands of tuner cars.
From GT-R Nismo to N1, to V-Spec (Victory), Nür (Nürburgring), M-Spec (Mizuno—the chief engineer), Z-Tune, LM Limited, Nismo 400R, a few more Nismo variants, an Autech (a four-door!), and various ‘Anniversary’ editions, there’s a rainbow of specifications, setups, and badges for someone to get their teeth into. Us? We’d have a Z-Tune. Or maybe an M-Spec Nür. Even we’re confused.
Pictured: 1998 Skyline 4-door GT-R Autech Version
7. Nissan said the R35’s ECU was ‘unhackable.’ ‘Hold my beer,’ said the tuners...
At the R35’s launch, Nissan proudly claimed that the car’s ECU was ‘unhackable.’ Within hours, tuners hacked it to bits. Because tuners are quite clever.
Cue a raft of GT-Rs with absolutely bonkers power outputs—and more than a few shattered gearboxes. There are cars reputedly out there running three and a half thousand horsepower (Extreme Turbo Systems—6.88sec 1/4 with a terminal of north of 350kph), but 800hp to 1,000hp isn’t uncommon, and a few relatively modest upgrades can see 700hp from a GT-R with reliability. In fact, when dealing with GT-Rs in general, pretty much all of them have some sort of modification—the real unicorns are the ones that are completely unmolested from the factory.
8. It’s nearly doubled in price, but it’s still a giant killer.
If we look at the ‘modern’ GT-R, a nice R32 back in 1991 cost around £42,500 (P2.88 million). An R33 in 1995 went up to £48,000 (P3.25 million), and the R34 in 1999 jumped to £54,000 (P3.65 million) for a standard model.
The GT-R (R35) cost around £58,000 (P3.93 million) when it came out—making it look like a proper bargain, and the latest 2019 GT-R weighs in at £81,995 (P5.55 million). Sounds expensive, until you realize that it’ll still put the wind up the Porsche 911 Turbo at £120,000 (P8.12 million), and worry the hell out of the Turbo S at £140,000+ (P9.48 million). In terms of punch relative to price, the GT-R still holds its head high.
9. The most mental GT-R sort of isn’t one.
This is true, as the R35 that runs in the absolutely mental GT500 class of the Japanese Super GT series doesn’t have a V6 engine or AWD. Instead, it utilizes the control motor for the series: a 2.0-liter, direct-injection four-cylinder turbo with around 650hp and 700Nm of torque. In fact, the entire chassis and carbon tub isn’t GT-R, either, running the same structure for all the models in GT500.
And the way that the aero is designed makes the GT500 GT-R pretty much just a shadowboxer: There’s an imaginary ‘design line’ around the waist of the car that means it has to stay normal-looking above, but can be designed for aero below. That means seriously odd-looking strakes, vents, and canards. About the only thing that is GT-R is the badge.
10. You can buy a GT-R that costs over a million dollars.
Yup, the Italdesign GT-R50 is an £885,000 (P59.9 million), limited 50-car series that won’t see the same car twice, built to celebrate—you guessed it—50 years of GT-R. Essentially, it’s a full-on Nismo Special with 710hp and 779Nm, and the show car featured beefed-up everything (engine, suspension, transmission), as well as stunning redesigned bodywork made mostly from aluminum and carbon fiber.
But the big news is that these Italdesign specials are pretty much bespoke—you can do anything you fancy (within reason), which means that the extremity of the execution is only limited by your imagination. And bank account.
PHOTO: TopGear.com
