As fuel prices continue to rise, switching to a hybrid or an EV is as tempting as ever. But not all of us have the option to trade in our internal combustion engine vehicle in exchange for a battery-powered four-wheeler.
After all, gas prices aren’t the only thing inflating these days. Everyday expenses are increasing as well, and our budget can only stretch so much before we find ourselves selling stuff on Facebook Marketplace to make up for our depleting funds.
While public transportation continues to improve, depending on where you live, there isn’t always an accessible bus stop or jeep route nearby. Some of us need to take four or more rides just to get to work.
5 Safety tips for motorcycle-taxi commuters
Keep it cool: 5 Simple tips to prevent overheating
So when bringing your ICE vehicle is the only realistic option left, don’t worry, we’ve got you covered. Here are five useful things you can do in 2026 to make every drop of fuel count. If you have any other useful tips, share them with our other readers in the comments.
1) Coast more, brake less
When driving—especially on the highway—you don’t always have to go at maximum speed, especially when the road is congested. Leave a couple of car widths between you and the vehicle in front so you can coast to slow down instead of abrubtly pressing on your brake pedal. You can also coast downhill if you aren’t going too fast to save on fuel while maintaining momentum.
2) Check your tire pressure
Your tires play a big role in how much fuel you consume, and a lot of it has to do with tire pressure. Your car’s ideal tire pressure should be in your owner’s handbook. You can also check the tire pressure chart usually found on your car’s driver-side door jamb.
A good rule of thumb is to check your tire pressure every two weeks. This makes sure you don’t drive with a lower PSI that will cause more drag and affect fuel consumption.
3) Avoid peak hours when you can
Rush hour is usually between 7am to 9:30am, and 5pm to 8pm. If possible, leave earlier than 7am to avoid heavy traffic on major roads. When the day ends, try to leave before 5pm or wait until 8pm to avoid the rush on the way home. Less time in traffic means more time for rest or work, and less gas wasted.
4) Wear thin-soled shoes
Wearing shoes with thinner soles behind the wheel gives you more control over the throttle. You can press the accelerator more precisely and reduce driving with a heavy foot which can save you fuel. If you want, you can even drive in socks for even more pedal feel, just make sure your floor mats are clean especially if you wear white socks.
5) Get rid of extra weight
If your car is constantly loaded with things you don’t need, you’re probably burning more fuel than you normally would. Only bring the essentials and leave the rest at home. Your car will be lighter, which not only saves fuel but also helps with better acceleration and braking. P.S. Absolutely do not leave your spare tire at home just to save weight.
