Motorcycle Feature
8 Underbones and backbones you can buy brand-new for under P60,000
Perfect for those eyeing a motorcycle but are on a tight budget
motorcycles, underbones, backbones, underbone motorcycle price philippines, backbone motorcycle price philippines, underbone motorcycles philippines price, backbone motorcycles philippines
PHOTO: Kawasaki, Honda, Yamaha
Let’s face it: Entry-level scooters are still pricey, at least when you compare them with other budget-friendly underbones and backbones.
While there are a lot of affordable scooters out there, the pickings get slimmer when you limit the budget to, say, P60,000. If you factor in manual motorcycles, though, there’ll be a lot more to choose from.
In this article, we’ll show you exactly that. We’ve listed here eight reasonably priced offerings from Honda Philippines, Yamaha Motor Philippines, Suzuki Philippines, and Kawasaki Philippines. If you’re in the market for an urban commuter or a two-wheeled workhorse that won’t break the bank, read on.
OTHER MOTORCYCLE STORIES YOU MIGHT WANT TO READ:
10 Scooters you can get for under P80,000
Everything you need to know about the Suzuki Burgman Street
1) Kawasaki CT100B
Kawasaki CT100B, underbone motorcycle price philippines
Price: P43,000
Engine specs: 102cc air-cooled, four-stroke single-cylinder
Maximum output: 7.7hp @ 7,500rpm, 8.24Nm @ 5,500rpm
Fuel system: carburetor
Fuel-tank capacity: 10.5 liters
Estimated fuel consumption: 93km/L at 50kph
Dimensions: n/a
Seat height: n/a
Ground clearance: n/a
2) Honda Wave110 Alpha
Price: P47,700
Engine specs: 109.16cc air-cooled, four-stroke single-cylinder
Maximum output: 8.17hp @ 7,500rpm, 8.46Nm @ 6,000rpm
Fuel-tank capacity: 3.7 liters
Estimated fuel consumption: n/a
Dimensions: 1,897mm x 706mm x 1,092mm
Seat height: 765mm
Ground clearance: 135mm
3) Kawasaki CT100
Price: P49,000
Dimensions: n/a
Seat height: n/a
Long-term review: 2020 Honda ADV150
Specs, prices, features: Everything you need to know about the Honda PCX160
4) Yamaha YTX 125
Price: P49,900
Engine specs: 125cc air-cooled, four-stroke single-cylinder
Maximum output: 8.05hp @ 7,000rpm, 10.2Nm @ 4,500rpm
Fuel-tank capacity: 7.6 liters
Dimensions: 2,040mm x 700mm x 1,070mm
Seat height: 800mm
Ground clearance: 170mm
5) Kawasaki CT125
Kawasaki CT125, underbone motorcycle price philippines
Price: P51,400
Engine specs: 124.5cc air-cooled, four-stroke single-cylinder
Maximum output: 9.86hp @ 7,500rpm, 10.5Nm @ 5,500rpm
Dimensions: n/a
Seat height: n/a
6) Honda TMX125 Alpha
Price: P53,400
Maximum output: n/a
Fuel-tank capacity: 8.6 liters
Estimated fuel consumption: 62.5km/L
Dimensions: 1,904mm x 754mm x 1,026mm
Seat height: 759mm
Ground clearance: 156mm
*Honda Wave110 (Drum Brake) also available for P56,900
OTHER MOTORCYCLE NEWS YOU MIGHT HAVE MISSED:
The Honda CB150X is now in PH with a P163,900 price tag
Budget a bit tight for the Honda CB650R? The new CB500F is now available at P354k
7) Suzuki Smash
Price: P59,400
Engine specs: 112.8cc air-cooled, four-stroke single-cylinder
Maximum output: 8.58hp @ 8,000rpm, 9Nm @ 4,000rpm
Fuel-tank capacity: 4.3 liters
Dimensions: 1,930mm x 655mm x 1,040mm
Seat height: n/a
Ground clearance: 130mm
8) Kawasaki CT150
Kawasaki CT150, underbone motorcycle price philippines
Price: P59,900
Engine specs: 149.5cc air-cooled, four-stroke single-cylinder
Maximum output: 12.6hp @ 8,000rpm, 12.7Nm @ 5,500rpm
Dimensions: n/a
Seat height: n/a
