The BYD Shark 6 DMO has officially landed on Philippine shores, marking BYD Cars Philippines’ first launch for 2025. The highly anticipated plug-in hybrid pickup made its rounds through multiple global markets, including South America and Australia, before finally reaching our country.
In Australia and countries like Colombia and Brazil, the Shark 6 has been advertised as a workhorse pickup with serious off-road capabilities. But locally, BYD Cars Philippines and distributor ACMobility have added an adventurous flair to the lore around the Shark 6. With its vehicle-to-load or V2L features, the electrified pickup aspires to be the perfect camping or road-trip vehicle for Filipino overlanders.
Powering the Shark 6 DMO are two permanent-magnet synchronous electric motors, a 29.6kWh BYD Blade battery, and a gasoline engine that acts as a generator to stretch the 100km electric-only range to a combined range of 800km. With one electric motor driving each axle, the drivetrain is essentially AWD.
The Shark 6 also packs specialized driving modes for motoring over mud, sand, and snow—ideal for camping or if your profession takes you on trails.
New details show that the Ford Ranger PHEV is quite a capable workhorse
More details of the all-new PH-spec Nissan Patrol have emerged
To put it into hard numbers, the Shark 6 measures 5,457mm long, 1,971mm wide, and 1,925mm tall, with a wheelbase of 3,260mm. Those dimensions officially make the Shark 6 longer, wider, and taller than both the Toyota Hilux GR-S and the Ford Ranger Raptor. However, the Shark 6 has a lower ground clearance, sitting 230mm off the ground.
At the back, the bed of the Shark 6 DMO has a capacity of 1,200 liters and packs a lot of outlets—three 220V sockets, to be exact. The truck also comes standard with a V2L adapter that adds another two outlets. With another 220V socket inside, that brings the total to five outlets, in addition to USB-A and USB-C ports.
The Shark 6 DMO boasts a maximum V2L power output of 29kW through its sockets, which should be enough to power some lights, a coffee maker, and perhaps even an induction cooker while you’re out camping. And in terms of pulling power, the Shark 6 can tow as much as 2,500kg or carry up to 830kg on its bed.
All of these features remain consistent between the Advanced and Premium variants of the Shark 6 DMO. What buyers can expect from the Premium variant is a much more comprehensive advanced driver-assistance system (ADAS) and a head-up display. Features like automatic emergency braking, land-departure warning, and blind-spot detection will be found on the higher configuration, while the Advanced variant will keep a six-sensor radar system and manual cruise control. If you want the full breakdown of specs, you can check out this article for everything you need to know about BYD’s first-ever pickup truck.
Inside, both variants feature a cabin dressed in leather, a big 12.8-inch rotating infotainment display mounted in the middle, and a 10.25-inch digital instrument cluster on the driver’s side.
The BYD Shark 6 DMO Advanced is priced at P2,098,000, while the Premium variant stickers for P2,298,000. First-time BYD buyers will be given a discount of P50,000, while existing BYD owners will get P50,000 on top of that, for a total discount of P100,000.
The first 30 unit orders were turned over to their owners shortly after the Shark 6 launch.
