Can I turn my regular Ford Ranger into a Ranger Raptor?
Warning: Not for the faint of heart
The Ford Ranger Raptor is one of the most anticipated releases of 2018, but the big question for enterprising and creative pickup truck enthusiasts is this: How can I turn my current Ranger into the badass Ranger Raptor?
Yes, we know what you are thinking. For some this might seem like a ridiculous endeavor, but if the aftermarket is any indication, count on Ranger Raptor clones to appear on roads soon. It’s inevitable, and not entirely impossible.
Here’s a loose ‘guide’ for creating a spec-accurate Ranger Raptor clone. Before we dive in, please note that if somebody is seriously thinking about doing this, we'd love to hear from you.
The grille
Unfortunately, the Ranger Raptor grille is unique to the model, so even if you manage to get your hands on one, you can’t just slap it on the current Ranger. You’d have to fabricate a grille yourself or have a fiberglass expert do it. Here’s why…
The fenders
These wide fenders are unique to the Ranger Raptor as well, and have their own dies for when the metal sheets are pressed at the factory. This shows Ford’s commitment to the Ranger Raptor model, actually. The fenders require their own pressings because the dimensions have changed dramatically.
The wider track, front and rear
Yes, you read that right. The Ranger Raptor is wider than the Ranger, and those bulging fenders with massive flares aren’t just for show. We suppose adding wheel spacers or using aggressive offset wheels and wider tires will give the desired look, but nothing can beat the original geometry that has been designed into the front double wishbones and Watt’s link at the rear. The front and rear tracks are at 1,710mm now.
The suspension
Keeping things in control are the position-sensing coilovers on all four corners. The Ranger Raptor’s engineers say that the Fox Racing Shox dampers are the gems of this new model, because this is obviously where a huge chunk of the performance comes from. If you’ve seen Baja 1000 videos, notice the smooth movements of the long-travel suspension. The Ranger Raptor is built to handle big air and hard hits like that. Suspension design is a sophisticated art, and in a performance truck like this, you can’t take any shortcuts.
Raising the ride height and widening the stance for looks is relatively easy, but having a suspension system that can perform in conditions found in the the Baja 1000 is another, more involved, more complicated, and more expensive, thing. Expert engineering is required. By the way, ground clearance of the Ranger Raptor is 283mm.
The reinforced frame
As said earlier, extra-long suspension travel and a wider track has been built into the Ranger Raptor, and the chassis has been reinforced and redesigned to cope with this. It was built to withstand hard impacts and uses various grades of high-strength low-alloy steel. The side rails are stiffer, and even the towing points have been rated to haul heavier loads. The shock towers are sturdier, too. Modifying a Ranger's frame to be tougher isn't impossible, but is a very involved process that requires the body to be removed from the frame. Unless the truck will see competition use, this might not be worth the trouble.
Unique interior
There’s a steering wheel (with paddle shifters) that is unique to the Ranger Raptor, and seats with bigger bolsters that hug the body. The blue stitching and leather accents are there to remind drivers about the link to the Ford Performance department. This look can be copied at a good upholstery shop, but finding the grippy and hard-wearing seat material might be tough.
The wheels and tires
You will notice that the wheel-and-tire-combo isn’t overly aggressive or huge at 285/70 R17. That's because the designers were going for the look and proportions of the F-150 Raptor. They did a good job in that respect. It won't be long until sets of these wind up for sale on the Internet. Keep an eye out for those.
Terrain management and 10-speed transmission
This is where it gets complicated. The Ranger Raptor is fitted with the same 10-speed transmission found on the F-150 Raptor. Cool. Why 10 speeds? Because this wide ratio results in better acceleration and responsiveness. And then there's the terrain-management system that has six modes, the most exciting of which is Baja Mode. In this setting, responsiveness is tuned for high-speed off-road driving. Traction control is less intrusive, and gears will be held longer and downshifts are more aggressive. We suppose you can find this transmission from a wrecked F-150 Raptor in the US, but when you do, you will have to pair it to this...
The all-new engine
Under the hood is a 2.0-liter bi-turbo diesel engine that delivers  210hp and 500Nm of torque. It also has loads of other goodies, including an integrated intake manifold and a belt-in-oil primary drive. The sequential turbos also ensure that there is adequate power throughout the rev range. And despite the smaller displacement, it outperforms the current 3.2-liter mill. A tuning expert can probably get the same performance out of the current engine.
This is the road to creating a Ranger Raptor clone with mods that aren't just skin deep. If all of this seems pretty daunting (and expensive), we suggest that you wait a while longer for the real thing to get here. According to Ford Group PH managing director Bertrand Lessard, the Ranger Raptor will be arriving at the tail end of 2018. Get your wallets ready.
PHOTO: Ford
