Spec-sheet brawl: Geely EX2 Pro vs. BYD Seagull
The sub-P1-M BEV hatch showdown
Image of the Geely EX2 and the BYD Seagull
ILLUSTRATION: Andrew Guerrero
Geely has finally revealed the full specs of its much-anticipated subcompact electric hatchback, the Geely EX2. For this spec-sheet brawl, we’ll be pitting the entry-level EX2 Pro variant against BYD’s popular Seagull electric city car. Let’s see how the new kid on the block stacks up against the established model.
At 4,135mm long, 1,805mm wide, and 1,580mm tall, the EX2 is 355mm longer, 90mm wider, and just as tall as the Seagull. Moving to ground clearance, there’s a decent 161mm between the ground and the car—a massive 41mm advantage over the BYD. This makes the EX2 about a size class larger than the Seagull.
Photo of the Geely EX2 at PIMS 2026
The EX2 is Geely’s new B-segment BEV hatchback. It has a rear-mounted 114hp electric motor driving the rear wheels. Another not-so-common feature is its 70-liter front trunk, aka frunk, in addition to its decent-sized 375-liter rear cargo area.
Watch: What’s it like living with the Kia EV5 for a few days?
Watch: Is the BYD Seagull still a good buy in 2026?
The Seagull is BYD’s electric city car; it’s technically an A-segment hatch. It has a more conventional layout with a 74hp electric motor mounted up front driving the front wheels. As expected, this has no frunk. The Seagull’s cargo capacity is a more modest 230 liters.
2025 BYD Seagull review
When it comes to passenger capacity, the larger EX2 is a full five-seater, while the Seagull is strictly a four-seater. The little BYD also lacks rear A/C vents. Meanwhile, in the safety department, these cars offer the usual ABS, stability control, and traction control. Both have four airbags.
Being a lower trim, the EX2 Pro does lose out on some items that the Seagull has. The base Geely has to make do with steel wheels with covers, while the Seagull gets alloys. In the tech department, the lower-trim Geely skips the wireless phone charger. Both electric hatchbacks have Apple CarPlay and Android Auto; the BYD, though, features a wireless setup.
BYD Seagull Geely EX2 size comparo
How much do these BEV hatchbacks cost? The EX2 Pro has a sticker price of P938,000, while the smaller Seagull carries a higher P968,000 price tag. Unlike the BYD, the Geely is also offered with a higher Max variant that costs an extra P100K. The range-topping EX2’s upgrades include 16-inch alloys, two more airbags, and ADAS, to name a few.
Still not sure which one to go for? Check out the spec sheet table we prepared and let us know which of these two small electric hatchbacks you’d choose.
SPECS: Geely EX2 Pro vs. BYD Seagull
Geely EX2 Pro
BYD Seagull
Price (Philippine peso) P938,000 P968,000
Drive RWD FWD
Seating capacity 5 4
Motor type electric motor (rear) electric motor (front)
Power (hp) 114 74
Torque (Nm) 150 135
Battery capacity 39.4 30
NEDC range (km) 395 300
0-50kph acceleration (sec) 4.6 4.9
Brakes (front/rear) disc/disc disc/disc
Wheels 15-inch steel with covers 16-inch alloy
Tires 205/65 R16 175/55 R16
Front suspension independent MacPherson strut independent MacPherson strut
Rear suspension independent multilink strut torsion beam
Seat material synthetic leather leather
Driver’s seat 6-way manual 4-way manual
Front passenger seat 4-way manual 4-way manual
Rear seat 60:40 split-folding folding
Infotainment system 14.6-inch touchscreen 10.1-inch touchscreen (rotating)
Connectivity Apple CarPlay + Android Auto Wireless Apple CarPlay + Android Auto
wireless charger no yes
Speakers 4 2 + 2 tweeters
Rear A/C vents yes no
Airbags 4 4
ABS with EBD yes yes
Electronic stability control yes yes
Traction control yes yes
Cruise control yes yes
Hill-start assist yes yes
Camera yes (rear) yes (rear)
Parking sensors yes (rear) yes (rear)
Headlights LED LED projector
Taillights LED LED
Dimensions (mm) 4,135 x 1,805 x 1,580 3,780 x 1,715 x 1,580
Wheelbase (mm) 2,650 2,500
Ground clearance (mm) 161 120
Turning radius 4.95 4.95
Cargo volume (L) 375 + 70 (frunk) 230
Curb weight (kg) 1,300 1,160
