The 5 N isn’t just a straight-line rocket. It goes around corners very well, too. Those big 21-inch wheels are shod in 275/35 R21 Pirelli P-Zero EV tires. They're surprisingly quiet, astonishingly grippy and worryingly thin. Despite this being an SUV, I wouldn’t drive this down a gravel path for fear of scratching those beautiful wheels. But thanks to the hardcore rubber, the 5 N has a lot of mechanical grip, if a tad less steering fluency than I'd like. But that’s what you get when you have ultra-wide sports rubbers on, and the level of steering response is commendably good.
Out on twisty switchbacks, the two ‘N’ buttons on the steering wheel come in handy. The one on the right engages the 5 N’s most celebrated party tricks: Fake gear shifts and engine sounds. The gear shifts feel absolutely convincing. They cut power between shifts, with a comically theatrical pause, before slapping you in the back as you ‘engage’ the ‘next gear.’ The fake engine sounds are less convincing, played through the internal and external speakers, they lack the buzzing vibration and thumping infrasound of a real combustion engine. You have a choice of aircraft turbine and sonic booms, snap-crackle-pop-pop-pop race engine, or electrowhiney ‘Evolution,’ which is the best of the three. Most buyers will turn these on once, giggle a little, then turn them off again, only using them occasionally to amuse friends bumming rides.
The left button accesses your custom drive modes. You can set up an N Sport+ mode with custom damping, steering and differential balance. The last one is slightly misleading, as the Ioniq doesn’t have a center differential. All it does is prioritize either the 200 horsepower front motor, or the 400 horsepower rear. So no, setting the bias to 100% rear doesn’t turn the Ioniq into the drift machine you hope it to be. Not, at least, without engaging N Drift Mode, which requires you to input your social security number, TIN and the Contra cheat code.
But even without drift mode, the Ioniq has a lovely character and balance. The low-slung battery and square stance make it rotate very keenly, and in the Sport+ setting, it feels like the anti-roll bars stiffen up to squelch any body roll.
