The safe way to remove your car’s battery
Avoid an accident by following these steps
PHOTO: Kaboompics.com/Pexels
Batteries are a great source of electricity for many gadgets and devices, but they’re very much a finite source of energy. Even if they’re rechargeable (like the batteries in our cellphones and laptops), with enough use they’ll eventually break down and need to be replaced.
Now, unlike the batteries in your TV remote which you can replace almost blindfolded, there are certain steps you need to follow when it comes to your car’s battery. Failure to follow these steps can be quite shocking. We don’t mean in a clickbait “The results will shock you!” sense, but more in a James Bond Goldfinger kind of way. Positively shocking.
But before we dive into how to replace your car’s battery, first we should explain what the battery’s purpose is in the first place. When your car is running, the alternator converts mechanical energy into electrical energy in order to power the car’s electrical components. This is what runs your car’s radio, lights, and so on when the engine is running. The battery, meanwhile, is in place to help start the engine. It also powers the electricals when the engine is off. So if you’re in the habit of listening to your music with the car parked, note that it can have an effect on your car battery’s longevity. But the battery does get recharged by the alternator while the car is in motion.
So now you might be wondering if only driving once in a blue moon will prolong your battery’s lifespan. Not so fast. You see, the battery needs that recharging process from the alternator in order to function over time. Without it, the battery will naturally drain as it falls into disuse. The fact that the battery also powers things like the engine control unit (ECU), alarm systems, and memory settings while the vehicle is parked only adds to the drain.
Now, there are many factors that can affect your car battery’s lifespan. Here are four reasons why your battery might drain earlier than expected:
1) It’s too small.
Just like how two TV remotes can require different sizes of batteries, your car will need a certain type of battery depending on its model and size. Using a smaller-spec battery will naturally result in a shorter lifespan. If in doubt, consult your retailer about the best kind of battery for your car.
2) You spend too much time in traffic.
Yeah, this one is kind of unavoidable for most of us, but the reality is that all the hours we spend stuck in gridlock can have an adverse effect on our car’s battery. The start-stop nature of traffic prevents the alternator from fully charging the battery. This can result in lead sulfate crystal build-up, otherwise known as sulfation. If your battery goes for long enough without charging properly, the sulfation process can have a harmful effect on its performance.
3) You don’t maintain it properly
It’s obvious, but it bears repeating. Like any other part of your car, failure to properly check and maintain your battery can seriously affect its longevity. Some battery manufacturers advise that you check it at least once a month for any leaks and to check if the top is clean. Also, always check the condition of the terminals, screws, clamps, and cables.
4) You overwork your car’s electrical components
As we mentioned, when your car’s engine is turned off, it’s the battery that’s powering the electricals. Leaving lights on or listening to the radio for prolonged periods of time will drain it quite quickly. We’ve all heard of those parking lot horror stories of motorists leaving their lights on and returning to a dead battery.
Okay, so now you know how a car battery works and what can cause it to drain prematurely. Now we’ll get into the proper steps of removing it when it needs replacement. First, some precautions:
  • For this job, you’ll need a screwdriver and an adjustable wrench. To be extra safe, we advise wearing insulated gloves and safety glasses as well. Zip ties are also handy for keeping cables secure and at bay.
  • Make sure the ignition is switched off and the key is removed from the car.
  • Remove any jewelry like rings and necklaces which can come into contact with the metal parts of the hood. You never want to be wearing metal when dealing with electricity.
  • Make sure the area you’re working in is dry and isn’t likely to be suddenly sprayed on with water (for example, working outside on a day predicted to rain).
Now, follow these steps when removing your car’s battery:
  1. Open the hood and find where the battery is located.
  2. Identify the negative terminal. This will usually have a minus (-) sign on it.
  3. Remove the negative terminal first. This very important. By doing this, you are disconnecting the battery from your car’s chassis. If you remove the positive terminal first and your metal tool makes contact with another metal part of the vehicle, you could cause a short in the system.
  4. Once the negative terminal has been removed and is out of the way, remove the positive terminal. Use zip ties as needed to secure any loose cables.
  5. Most batteries nowadays also have a bracket to secure it in place. If there is one, remove that once both the positive and negative terminals have been disconnected.
  6. Once the securing bracket has been taken out, you may now lift the battery out. If this is your first time lifting a car battery, it might be heavier than you expect, so make sure you’re on solid footing first.
  7. To place the battery back in place, simply repeat steps 2-6 but in reverse. So place the battery, install the securing bracket, connect the positive terminal first, then finally connect the negative terminal in place.
Remember, if you’re in doubt or you feel uneasy about doing removing your car’s battery, consult the help of a professional mechanic.
