Honda Philippines (HPI) has continued to revamp its scooter lineup over the past few years. In addition to the top-selling Beat and Click, the company bolstered its offerings further with a couple of small-displacement maxi-scooters.
One is the ADV 150, and the other is the PCX 160. The latter is one of the freshest arrivals in the roster. This stylish, fuel-efficient two-wheeler is continuing to cement itself as one of the most ideal urban runabouts in the market today.
Are you a rider eyeing this scooter? If so, then scroll on, because we’re here to run you through everything you need to know about the all-new Honda PCX 160.
Vintage Vehicle Regulation Act IRR to take effect on April 17
Meanwhile in Malaysia, the Toyota Supra gets a manual
Pricing
There are two variants of the Honda PCX 160. The CBS version is priced at P120,900, while the ABS sells for P139,900.
The ABS variant can be had in Asteroid Black Metallic, while the CBS can be had with a Matte Dim Gray Metallic finish. The Pearl Fadeless White color option is available for both trims.
Design and dimensions
The Honda PCX 160 measures 1,936mm long, 742mm wide, and 1,108mm tall. Seat height is listed at 764mm, while ground clearance is at 135mm. The bike has a curb weight of 131kg and an eight-liter fuel tank and sits on 14-inch front and 13-inch rear tires. The front wheel is shod in 100/70-14MC tubeless tires, while the rear gets 130/70-14MC tubeless tires.
Unlike the ADV 150, the PCX 160 isn’t a miniature version of a Honda big bike, which is why this scooter boasts somewhat original styling. This one has a much classier look than any of its stablemates, with sharp lines and smooth surfaces making up the front end. The PCX 160 has an uncanny resemblance to the Click and the ADV 150 with the scooter’s large V-shaped headlamp that takes up most of the real estate up front.
On the sides, you’ll see the foldable footpegs that, when retracted, somewhat camouflage into the body. Out back, the scooter gets an almost X-shaped taillight that gives it one of the prettiest light signatures in Honda’s lineup.
OTHER HONDA STORIES YOU MIGHT WANT TO READ:
The Honda CB150X is now in PH with a P163,900 price tag
Budget a bit tight for the Honda CB650R? The new CB500F is now available at P354k
Engine and specs
The Honda PCX 160 is powered by a new liquid-cooled, single-cylinder 157cc eSP+ gasoline engine that generates 15.8hp at 8,500rpm. The fuel-injected powertrain supposedly does 45.1km/L according to Honda.
The scooter is equipped with front and rear disc brakes. The ABS version, of course, gets an anti-lock braking system, while the lower variant features a combi-braking system.
Extra features
The PCX 160 comes equipped with a few amenities that make it ideal to use as a daily in the metro. For starters, it gets a smart key with an answer-back function and a keyless ignition system. Its instrument cluster, meanwhile, includes a trip meter and a fuel-consumption indicator.
There’s a small compartment right underneath the lefthand side of the handlebar. This cubby’s big enough for a smartphone, keys, and probably a small wallet. This houses the built-in USB charging port. Under the seat, the PCX 160 boasts 30 liters of storage space, which is enough to fit a small half-face helmet and then some.
The higher PCX 160 variant is also equipped with Honda Selectable Torque Control (HSTC) which works hand-in-hand with the ABS to ensure safe braking. Lastly, the bike has an idling stop system that comes as standard.
More photos of the 2022 Honda PCX 160:
