Motorcycle Review
First ride: The Honda Click 160 is easily worth the upgrade
Something current Click customers should keep in mind
Honda Click 160 2023
PHOTO: Leandre Grecia
So this is the new Click?
Oh yes. It’s the new and updated scooter with the beefier 160cc engine. Honda Philippines (HPI) recently had us test this along with the new AirBlade 160.
It sure looks new. Tell us more about it.
Unlike the AirBlade, the Click is styled differently from its predecessor. The signature V-shaped headlight is still visible, but it’s now split by plastic trim up front. It actually gives the scooter a more muscular look.
Why does it look cleaner than the old Click?
That’s because it is. Honda has dropped all the decals here and opted for a simpler design with solid body colors to make up the two-tone or monotone look. The logos are now embossed 3D badges as well. You’re looking at new colors, too: Matte Pearl Crater White, Matte Gunpowder Black Metallic, and Matte Solar Red Metallic. All of these matches nicely with the brown wheels underneath.
Driver follows navigation app, ends up on train tracks
Here’s your first look at the ASEAN-spec Honda CR-V
Enough about the design. What’s up with the engine?
The new Click 160 is powered by a 157cc liquid-cooled, single-cylinder, fuel-injected gasoline engine capable of 15hp at 8,500rpm and 13.8Nm of torque at 7,000rpm. We weren’t able to test this outside the Honda Safety Driving Center, but according to Honda’s figures, this should be able to do up to 46-47km/L. Not too shabby.
Does the slightly bigger engine make a difference?
In terms of fuel economy, we’re not sure yet. But as far as performance goes, there’s a noticeable gap between the two.
As with the AirBlade, we were also able to test the old and new Clicks back-to-back, and I could really tell the difference between the two. The Click 160 has significantly less dragging from a standstill, and it gets up to speed quicker than the Click 150 as well. It appears the power boost can be felt for the majority of the rev range.
Has this affected the ride?
Frankly, the mechanical changes haven’t really impacted the ride at all. The old and the new Click still feel the same when you’re on the road. But of course, I could be wrong—we’ll find out when we finally get to take the new Click 160 out for a full review.
Does the new Click have ABS?
Unfortunately, Honda has reserved that safety feature for the AirBlade. The Click 160, though, gets a combi-brake system (CBS) that applies pressure to both front and rear brakes whenever one lever is pressed. This enables safer and smoother braking.
Very well. What other new features does it have?
Honda has retained the instrument cluster of the old Click, so the information you get from that display is basically the same. What’s new here are the USB charging port (bye-bye 12V socket adapters) and the enclosed left glove compartment. As with the AirBlade, the Click now also has a different keyless ignition mechanism that can be turned as long as the smart key is in range.
How much for this one?
The new Honda Click 160 stickers for P116,900, or a few thousand pesos short of its AirBlade sibling. The new Click 160 variant now replaces the old Click 150 in HPI’s lineup.  If you ask me, even if the scooter may be lacking in some tech here and there, the new model will still easily be worth the upgrade.
If you want to learn more about the new Click 160, you can check out this other story instead. You can also watch our first impressions video below.
