Isuzu D-Max 2022: Everything You Need to Know
Talk about shaking up a segment
PHOTO: Teddy Garcia
Isuzu Philippines Corporation went all out overhailing their line-up these past couple of years. One of those leading the charge was the all-new D-Max which was launched last year.
We know a lot of you are eager to find out more about what the current-generation model has to offer, so we’ve put together here everything that you need to know about this midsize pickup. Not only that, you're probably curious how it fares against the newest kid on the block, the fourth-gen Ranger. Let’s get right to it.
Exterior
Isuzu D-Max 2021 exterior
The all-new D-Max boasts an angrier-looking face than before, with a pair of snazzy chrome strips and a large blacked-out grille highlighting the front end. The headlamps and the foglights have been given a major redesign, too, while the rear end has been slightly tweaked for a sportier look.
Wheel options include 15-, 17-, or 18-inch wheels with silver or matte dark-gray finishes. Top-spec D-Max variants get additional dark plastic bits on the outside that give the truck more style.
A wide range of color options are available, namely: Valencia Orange, Onyx Black, Mercury Silver, Red Spinel, Sapphier Blue, Galena Gray, and Splash White.
Interior
Isuzu D-Max 2021 interior
The D-Max’s cabin gets a major overhaul as well. Bucket seats are now fitted across the range, and these are stitched with cloth, black fabric, or brown leather depending on the variant. The range-topping D-Max boasts a more premium interior thanks to the plethora of leather and soft-touch materials around the cabin.
Engine and specs
Isuzu D-Max 2021 engine
Isuzu has given its trusty truck a new 3.0-liter 4JJ3-TCX Blue Power turbodiesel that generates 187hp and 450Nm of torque, which is a significant boost from the previous model’s figures.
A second engine is also available: the familiar 1.9-liter RZ4E turbodiesel that’s capable of 148hp and 350Nm of torque. It’s the same engine, but Isuzu has supposedly tweaked it to improve performance and reduce noise and vibration. Both powertrains can be had with either a five-speed manual or a six-speed automatic.
Stopping power is provided by ventilated disc brakes up front and drum brakes out back. The pickup’s chassis has also been reinforced—it’s now bigger and more rigid for improved handling and stability. Isuzu says the 4x4 variants now have better approach, departure, and ramp-over angles. Wading depth, meanwhile, is now at 800mm.
Extra features
Isuzu D-Max 2021 infotainment display
The D-Max now comes with a lot of added toys, and the top-of-the-line variant gets all the bells and whistles. Standard features first: Save for the base LT variants, the range gets a 4.2-inch instrument cluster to go along with the new Apple CarPlay- and Android Auto-compatible 10.1-inch infotainment system, as well as rear A/C vents. The infotainment system, by the way, comes with a built-in navigation system and clinometer.
As for the top variant in the range, extra niceties include an eight-speaker setup (other trim levels have six), rain-sensing wipers, an auto-dimming rearview mirror, automatic climate controls with a dual-zone function, a smart keyless entry system with a push-to-start ignition, and a remote start feature.
It also comes equipped with a myriad of safety tech like forward-collision warning, turn assist, pedal misapplication mitigation, blind-spot monitoring, lane-departure warning, rear cross-traffic alert. Front and rear parking sensors with a reversing camera are available, as is adaptive cruise control, autonomous emergency braking, and a multi-collision brake system.
Prices and variants
Isuzu D-Max 2021 front exterior close up
The Isuzu D-Max’s prices range from P857,000 to P1,825,000. For a more detailed look, you can refer to the list below:
2022 Isuzu D-Max lineup:
  1. Isuzu D-Max RZ4E Single-Cab 4x2 MT – P857,000
  2. Isuzu D-Max 3.0 Single-Cab 4x4 MT – P1,113,000
  3. Isuzu D-Max RZ4E LT 4x2 MT – P987,000
  4. Isuzu D-Max 3.0 LT 4x4 MT – P1,288,000
  5. Isuzu D-Max 3.0 LS-A 4x2 MT – P1,320,000
  6. Isuzu D-Max 3.0 LS-A 4x2 AT – P1,390,000
  7. Isuzu D-Max 3.0 LS-A 4x4 MT – P1,630,000
  8. Isuzu D-Max 3.0 LS-E 4x4 AT – P1,825,000
What do you think of the all-new Isuzu D-Max? Tell us in the comments.
Isuzu D-Max 2021 left headlight
Isuzu D-Max 2021 plate
Isuzu D-Max 2021 step
Isuzu D-Max 2021 wheel
Isuzu D-Max 2021 wheel buttons
Isuzu D-Max 2021 engine start stop button
Isuzu D-Max 2021 aircon buttons
Isuzu D-Max 2021 aux
Isuzu D-Max 2021 dashboard
Isuzu D-Max 2021 leather material
Isuzu D-Max 2021 driver side
Isuzu D-Max 2021 interior from the outside
Isuzu D-Max 2021 backseats
Isuzu D-Max 2021 back of driver's seat
Isuzu D-Max 2021 aircon vent
Isuzu D-Max 2021 exterior back closeup left Isuzu D-Max 2021 exterior closeup right
Isuzu D-Max 2021 logo at the back
Isuzu D-Max 2021 lse 3.0TD
Isuzu D-Max 2021 tire closeup
PHOTO: Teddy Garcia
