Spec-sheet brawl: Nissan Navara Pro PHEV LE vs BYD Shark 6 DMO Premium
The electrified pickup face-off
photo of the nissan navara pro phev side-by-side with the byd shark 6 dmo
ILLUSTRATION: Andrew Guerrero
Nissan Philippines recently launched its much-awaited Navara Pro PHEV. The new electrified pickup is built by Zhengzhou Nissan, the Japanese automaker’s joint venture with Dongfeng. The plug-in hybrid model sits above the familiar diesel Navara range.
For this spec-sheet brawl, we’ll be pitting the electrified newcomer against the popular BYD Shark 6. Let’s see how the new challenger from a legacy brand stacks up against the crowd favorite. We will be using the range-topping variants of each pickup.
Photo of the 2027 Nissan Navara Pro
Both the electrified pickups sit on the larger end of the mid-size pickup segment. At 5,457mm, the Navara Pro PHEV is 37mm longer than the Shark. The BYD, on the other hand, is 11mm wider. When it comes to ground clearance, the Navara Pro PHEV’s 232mm has a 2mm advantage over the Shark. Water-wading depth is an equal 700mm for both electrified pickups.
Free Grab shuttles from NAIA T3 to One Ayala, PITX are available on weekends until Dec. 21
Side quest: Thrillscape at Okada Manila can heal your inner ‘American Ninja Warrior’
For safety, both the Nissan and BYD get advanced driver-assistance systems. The Shark Premium gets additional safety features like blind-spot monitoring and rear cross-traffic alert.
Both vehicles offer quite modern interiors. The Navara Pro PHEV gets a massive 14.6-inch fixed infotainment touchscreen, while the Shark gets a 12.8-inch touchscreen that, although smaller, rotates. Compared to the BYD, the new Nissan has more physical controls. Thankfully, both feature dual-zone climate control and rear air-con vents.
BYD Shark 6 DMO 2025 photo
Here are two interpretations of an electrified body-on-frame pickup. Nissan goes the more familiar route with a single electric motor, a mechanical four-wheel-drive system, and a rigid rear axle. Meanwhile, BYD goes with dual motors, an electric all-wheel-drive setup, and independent rear suspension. Interestingly, both automakers agree on equipping their electrified pickups with large 31.6-inch diameter 265/65 R18 tires, about an inch taller than what most current traditional diesel pickups get.
The Navara Pro PHEV gets a 20.24kWh battery, compared to the Shark’s 29.6 kWh battery. Although Nissan Philippines hasn’t released the total combined range of its electrified pickup, it has published an EV range of 75km, 25km less than the BYD’s.
How much are they? The Navara Pro PHEV LE stickers in at P2,698,000 (P2,648,000 introductory price), while the BYD Shark Premium carries a lower P2,618,000 price tag.
We know choosing the right vehicle can be quite difficult particularly when both have their own strengths. Have a look at the side-by-side spec-sheet table we prepared and let us know which electrified pickup you’d like to take on an adventure.
Price (Philippine Peso) 2,698,000 2,618,000
Drive 4WD AWD
Seating capacity 5 5
Main power unit single electric motor dual electric motors
Power (HP) 209 228 (front), 201 (rear)
Torque (Nm) 350 310 (front), 340 (rear)
Battery capacity (kWh) 20.24 29.6
Electric NEDC range (km) 75 100
Assisting Power Unit 1.5 liter turbocharged in-line-4 gasoline 1.5 liter in-line-4 gasoline
Power (HP) 141 181
Fuel capacity (L) 67 60
Brakes (Front/Rear) ventilated disc/ ventilated disc ventilated disc/ ventilated disc
Wheels 18-inch alloy 18-inch alloy
Tires 265/65 R18 265/65 R18
Front suspension independent double wishbone independent double wishbone
Rear suspension 5-link rigid axle w/ coil springs independent multi-link
Seat material Leather Leather
Driver's seat 6-way power-adjustable
6-way power-adjustable w/ 4-way lumbar support
Front passenger seat 4-way power-adjustable 4-way power-adjustable
Infotainment system 14.6-inch touchscreen 12.8-inch touchscreen (rotating)
Connectivity wireless Apple Carplay & Android Auto wireless Apple Carplay & Android Auto
Wireless charger yes (50W) yes (50W)
Speakers 12 8
Rear A/C vents yes yes
Airbags 6 6
ABS w/ electronic brakeforce distribution yes yes
Electronic stability control yes yes
Traction control yes yes
Cruise control yes (adaptive) yes (adaptive)
Hill descent control yes yes
Forward-collision warning yes yes
Automatic emergency braking yes yes
Lane-keep assist yes yes
Blind-spot monitor no yes
Rear cross-traffic alert no yes
Camera 360-view w/ transparent view 360-view w/ transparent view
Parking Sensors front + rear front + rear
Headlightsq projector LED LED
Taillights LED LED
Power-operated tailgate yes no
Running board yes (power-retractable) yes
Dimensions (mm) 5,494 x 1,960 x 1,945 5,457 x 1,971 x 1,925
Wheelbase (mm) 3,300 3,260
Ground clearance (mm) 232 230
Towing capacity (kg) 3,500 2,500
Water wading depth (mm) 700 700
