This Porsche 911 packs a V6 from Niki Lauda’s F1 car from the ’85 French GP
It’s number six of 11 bespoke Lanzante 930 TAG Turbo cars
Rear view of the Lanzante 930 TAG Turbo
PHOTO: TopGear.com
What do you get if you cross a wild Formula 1 V6 engine with a classic Porsche 911? Nope, it’s not the latest in a string of lamentable dad jokes. When Mercedes first announced its intention to create the AMG One—putting an F1 engine into a street-legal road car—we knew it wasn’t the only time it had been done.
So, a warm welcome back to the Lanzante 930 TAG Turbo.
What’s a Lanzante 930 TAG Turbo?
Front view of the Lanzante 930 TAG Turbo
It’s a ‘930’ Porsche 911 Turbo fitted with a real-life 1.5-liter Formula 1 V6 TAG-Porsche engine. Not a V6 built to copy that engine, but one of the actual units originally developed in the early ’80s that helped Niki Lauda, Alain Prost, and McLaren to dominate the 1984 and 1985 F1 seasons.
Everything you need to know about the Metro Manila single ticketing system
Here’s everything that’s new in the 2023 Honda Brio
What’s the story?
McLaren—desperate to jump on the turbo V6 train and rival Renault’s 1982 championship-winning engine—joined forces with TAG and Porsche in the early ’80s to create a turbocharged F1 engine. The creative brain behind this unit was one Hans Mezger, Porsche’s legendary engineer responsible for some of the finest performance engines ever built.
After a lot of back and forth—the vagaries of which we haven’t got time to repeat here—a unit emerged, and during testing, it was hilariously put in the back of a 911 Turbo road car. Years later, of course, this would inspire Dean Lanzante to build his own, which is why we’re here.
Ooh, okay. Tell me more.
Image of the Lanzante 930 TAG Turbo
Though McLaren wouldn’t sell Lanzante the original engine, it did sell the 11 units that made up the season’s supply. That means Lanzante and the team have embarked on a project to create 11 custom 930s, each with a unique, F1-raced engine.
They’re all built from the ground up. Lanzante partnered with Cosworth to get the 1.5-liter V6 into the body of a 930, though obviously, it’s been turned down quite significantly from its blistering 1,000hp F1 heights to a more road-legally acceptable 503hp. There’s 420Nm of torque on tap, a 9,000rpm redline, and a top speed of almost 320kph.
Lexus’ first electric SUV is now in PH with a P4.828-M price tag
Toyota affiliate Daihatsu admits rigging cars for better crash test results
Naturally, a lot of work’s gone into making that F1 unit manageable. The six-speed gearbox has been given bespoke ratios, there’s a limited-slip diff, and to improve drivability and reliability, Cosworth decreased the boost pressure by 25%, switched up the fuel-to-air ratio to make lower speeds more comfortable, and introduced a new crankcase and smaller turbos.
A unique front-mounted radiator is part of a new water-based cooling system, replacing the old air-cooled one. There are also new coilovers and carbon brakes... but no traction control.
Side view of the Lanzante 930 TAG Turbo at Goodwood
The Lanzante 930 sits on 17-inch Ruf wheels (as opposed to the Turbo’s Fuchs rims), and while you can’t tell without opening the hood, there is a heady mix of aluminum and carbon fiber that helps shave 200kg from the standard build.
Lanzante wants to keep the interior as original as possible. Although all 11 examples will be entirely unique, there are some restrictions on what customers can spec. Porsche colors and upholstery choices from the period will be available. Modern stuff? Not so much.
RELATED STORIES:
Chinese Porsche dealer accidentally lists Panamera for sale at just P990,500*
We will never get tired of seeing a 964 Porsche 911 get the restomod treatment
There are, of course, hidden conveniences like USB ports, and Porsche Classic has helped supply some retro-fashioned media choices.
Sounds mega.
Front quarter view of the Lanzante 930 TAG Turbo
It does. As you’d expect, the crescendo from that V6 is heart-stoppingly sublime, and frankly, spectator vids from the Goodwood FoS 2019 debut don’t do it the justice it deserves.
The car pictured above is the sixth build. It’s finished in copper brown with a checkered tan interior, and the V6 on board this one is Niki Lauda’s engine from the 1985 French GP. Yeah, exactly.
PHOTO: TopGear.com
