Spec-sheet brawl: Mitsubishi Montero Sport vs. Nissan Terra
You asked for it, and now we have it
ILLUSTRATION: Teddy Garcia
In our last midsize SUV bout, we pitted the newly face-lifted Mitsubishi Montero Sport and the Ford Everest against each other. That was a fitting side-by-side comparison, to be honest, but we did notice that our readers were looking for a different matchup for the Montero: The Nissan Terra.
Of course, we at Top Gear PH are more than happy to oblige, so we’re here to give you what you asked for. Although we only lined up the 4x2 variant of the Terra because Mitsubishi Motors Philippines has yet to bring in the 4WD model of the beloved Montero Sport. Also, since the Toyota Fortuner still hasn’t received a proper facelift as of writing, its battle with its biggest rival will have to wait. With those out of the way, let’s get to it.
The Nissan Terra is relatively a newcomer in the Philippine market, having been introduced only in May 2018. The Mitsubishi Montero Sport, on the other hand, landed on Philippine shores way back in 2005 and has had its fair share of visual changed over the years, some of which stirred quite the debate (yes, we’re talking about the teardrop taillights). Nevertheless, in such a stacked segment, both vehicles have proven to be worthy competitors in their own rights.
The Montero Sport is powered by a 2.4-liter turbodiesel capable of 176hp and 430Nm of torque, and this engine is mated to an eight-speed automatic transmission. Meanwhile, the Terra packs a 2.5-liter turbodiesel that generates 187hp and 450Nm under its hood, and the said powertrain is mated to a seven-speed automatic transmission. Both vehicles offer a plethora of driver-assist and safety features in its arsenal, which makes this an even closer contest than it already is.
Price-wise, it’s just as tight: The Terra (P1,919,000) is more affordable than the Montero Sport (P1,998,000) by only a slight margin, so it still boils down to which vehicle offers the better value for money. What do you think? See more of the details below, and tell us whether Nissan or Mitsubishi bags the victory this time around.
2020 Mitsubishi Montero Sport GT 2WD
2020 Nissan Terra 4x2 VL A/T
Price (Philippine Peso) 1,998,000 1,919,000
Drive RWD RWD
Seating capacity 7 7
Engine 2.4L turbodiesel 2.5L turbodiesel
Power 176hp 187hp
Torque 430Nm 450Nm
Fuel tank capacity (liters) 68 80
Transmission 8-speed AT with Sports Mode 7-speed AT with manual mode
Wheels 18-inch alloy 18-inch alloy
Brakes (Front/Rear) Disc/disc Ventilated disc/drum
Tires 265/60 R18 255/60 R18
Front suspension Double wishbone with coil springs and stabilizer bar
Independent double-wishbone with coil spring and stabilizer bar
Rear suspension 3-link coil springs with stabilizer bar 5-link coil spring with stabilizer bar
Seats Leather Leather
Tailgate Power lift with hands-free function Manual
Keyless entry/Push-start ignition Yes/Yes Yes/Yes
Audio System 8-inch infotainment system with 6-speaker setup
Android Auto/Apple CarPlay Yes/Yes Yes/Yes
Paddle shifters Yes No
Tilt/telescopic steering wheel adjustment Yes Tilt only
Airbags 6 6
Active stability/traction control Yes/Yes No/No
Speed-sensing door locks Yes No
Blind spot monitoring/lane-keep assist No/No Yes/Yes
Parking assist Reverse sensors with camera
Reverse parking sensors with around-view monitor
Hill start assist Yes Yes
Hill descent control Yes No
Cruise control Yes Yes
Ground clearance (mm) 218 225
Wading depth (mm) 700 800
Dimensions (mm) 4,785 x 1,815 x 1,805 4,885 x 1,865 x 1,835
Wheelbase (mm) 2,800 2,850
