Spec-sheet brawl: Suzuki Swift vs. Toyota Yaris
A hatchback showdown
Outside of the rainy season and its looming threat of flood, a small hatchback is the ideal type of vehicle for moving around in urban areas. The segment's small, city-friendly package--with its convenient maneuverability and easy-to-park dimensions--just makes sense.
When it comes to hatches, two nameplates that are common sight across Metro Manila are the Suzuki Swift and Toyota Yaris. The former just saw its all-new iteration launch a couple of months ago, and the latter received a significant refresh late in 2017.
Price-wise, this matchup is pretty polarizing. The Swift 1.2 GLX CVT comes in at P899,000 while the Yaris 1.3 E MT carries a tag of P875,000--pretty costly considering the Suzuki is a spec-packed, top-of-the-line offering and the Toyota is a base model.
Fortunately for the Yaris, it has a couple of things going for it. Its 1.3-liter gasoline engine packs more punch at 98hp and 123Nm, compared to the Swift's 82hp and 113Nm. It also comes with knee, curtain and side airbags, while the Swift is only equipped with driver and front passenger airbags. And safety is something every car buyer has to consider when buying brand-new.
The two vehicles' turning radiuses and dimensions are worth a look, too. While the Swift is more maneuverable with a 4,800mm radius, it's considerably shorter than the Yaris and sacrifices on cargo room and space.
So, which one would you buy? Take a look at the specs and let us know in the poll below.
Suzuki Swift 1.2 GLX CVT Toyota Yaris 1.3 E MT
Price (Philippine Peso) 899,000 875,000
Drive FWD FWD
Seating capacity 5 5
Engine 1.2-liter gasoline 1.3-liter gasoline
Power 82hp @ 6,000rpm 98hp @ 6,000rpm
Torque 113Nm @ 4,200rpm 123Nm @ 4,400rpm
Fuel tank capacity (liters) 37 42
Transmission CVT Five-speed manual
Brakes (front/rear) Ventilated disc/drum Ventilated disc/drum
Front suspension MacPherson strut with coil spring MacPherson strut with stabilizer
Rear suspension Torsion beam with coil spring Torsion beam with stabilizer
Wheels 16-inch alloys 15-inch alloys
Tires 185/55 R16 185/60 R15
Airbags Driver/passenger Driver/passenger, knee, side, curtain shield
Dimensions (mm) 3,840 x 1,735 x 1,495 4,115 x 1,700 x 1,475
Wheelbase (mm) 2,450 2,550
Turning radius (mm) 4,800 5,100
ILLUSTRATION: Raynand Olarte
