Which is more expensive to maintain: MT or AT?
An age-old question
Manual vs automatic transmission
PHOTO: Honda
When acquiring a new vehicle, it’s only right to consider the cost of maintenance as it is an intrinsic component of car ownership. The car’s transmission is one of its principal components that require care and maintenance for the vehicle to run at optimum condition. Ordinarily, the transmission doesn’t get as much attention as the engine, the suspension, or the brakes. But it’s there, it’s important, and it also needs maintenance.
We can’t help but wonder why so many tricycles in Manila City have no license plates
Size comparo: How big is the all-new Toyota Innova compared to the Geely Okavango?
There’s really no hard and fast rule for saying which between a manual or an automatic is less expensive to maintain. But there are general rules, and there are also exceptions.
Under ordinary, normal circumstances, manual transmissions are cheaper to maintain and repair than automatics. This is especially true these days with the myriad of new technologies in the latter. Automatic gearboxes have more parts and far more complex systems that can fail. There’s a host of electronic and/or hydraulic systems working together to shift the gears for you. In a manual transmission, meanwhile, it’s you that does all this work. So on the surface, because of the complexity of modern automatic transmissions, they’re more expensive to maintain and repair.
One of the regular maintenance requirements for the transmission is a fluid change in an automatic and a gear-oil change in a manual. An automatic transmission requires automatic transmission fluid (ATF), while a manual transmission requires gear oil. However, an automatic transmission requires far more ATF than the amount of gear oil that a manual requires. This is because the torque converter in an automatic needs about twice as much ATF as the amount of gear oil that a manual needs. So for every fluid change, the service will cost at least twice as much for an automatic.
When an automatic transmission breaks down, the cost of fixing it will vary widely based on the brand of the vehicle and the nature of the repair. Fixing a fluid leak might cost a few thousand pesos, but taking apart the transmission can be far more expensive and time-consuming. You might be advised to replace the transmission instead of having it rebuilt, especially with newer automatics like CVTs and dual-clutch gearboxes, which are harder to fix and whose parts are more difficult to source. There are sensors, batteries, and computers separate from the ones in the engine that may need to be replaced. Traditional manual transmissions, on the other hand, are nowhere near as complex, and can be easily rebuilt with the sufficient know-how of local mechanics and parts that are more easily sourced.
The costs of replacing a transmission can also have wide variances in terms of brand. Ordinarily, however, a manual transmission will cost much less to replace. We’re talking hundreds of thousands when it comes to replacing these new automatic transmissions. If it’s an older car—and, heaven forbid, an older European luxury car—the cost of replacing the automatic transmission may even exceed the value of the entire vehicle.
That said, there are times that an automatic transmission can be cheaper to maintain than a manual. If you have a manual car and you burn through clutches quickly because of your driving style, your maintenance costs will most likely exceed that of an automatic transmission because you’re buying and replacing the clutch more often. For those of us who tend to do power launches frequently, a clutch is a regularly consumed item.
Abusive driving styles don’t affect automatic transmissions as much as they affect manuals. This is because the hydraulic and electronic control systems combined with modern computers that control the shifting in them simply won’t allow it. Modern advancements like these make automatics very durable even when driven hard.
Hopefully, this helps you decide if you’re on the fence in choosing between a manual or an automatic vehicle for your next ride.
PHOTO: Honda
