Goodbye Audi e-tron, hello Audi Q8 e-tron
Meet the new top-spec Audi electric SUV
Audi Q8 e-tron
PHOTO: TopGear.com
The Audi e-tron is dead. Long live the Audi Q8 e-tron, which becomes the company’s new range-topping electric SUV. There’s an ‘S’ version too, of course, surprisingly called the SQ8 e-tron.
More on that later. The standard Q8 e-tron—which we shall refer to as eQ8 because it’s simpler—wears its new nameplate atop a subtly redesigned body, notable via the new front and rear. We’re told it wears a new corporate identity: a 2D imprint of those famous four rings. Handsome, for something like this.
As before, it comes in either regular SUV shape or Sportback (the coupe-fied one). Measuring just under 5m long like the car it replaces (just shy of a Merc S-Class, for context), it features a twin-motor all-wheel-drive powertrain producing 335hp in the ‘50’ e-tron, or 403hp in ‘55’ e-tron. Nope, still no sense.
Audi Q8 e-tron
Each motor now packs an additional pair of coils—14 rather than 12—which apparently allows them to kick out more torque from less electricity. Every eQ8 comes with air-suspension able to adjust body height by 76mm, while the ESC system has been calibrated for “more adjustability, especially in tight corners.”
Just like the outgoing Audi e-tron S, this new SQ8 boasts a tri-motor setup, here producing a very healthy 500hp output via the bigger of the two batteries on offer. Audi hasn’t released any 0-100kph data, but we do know this car is lower and a fair bit wider than the regular cars, and the old car did it in 4.5s.
There’s quicker, more feelsome steering onboard across all three eQ8s, and Audi says all the chassis control systems have been adjusted but remain “balanced,” because even elephants like to dance, y’know.
Let’s address the other elephant in the room—range. The 335hp version features an 89kWh battery and gets a claimed range of up to 452km in the SUV and 467km in the Sportback, no doubt owing to the latter’s slipperier bodyshape. Indeed both cars get a better drag coefficient thanks to better underbody airflow, bigger front axle spoilers and new rear axle spoilers.
The 403hp car offers up a little more—bigger battery (106kWh), with a claimed 531km range in the SUV and 552km for the Sportback, and Audi reckons this unit can be charged from 10 to 80%—up to 386km—in just 31 minutes using a 170kW charger.
Audi Q8 e-tron
You can avoid the vagaries of the public charging lottery by getting an 11kW wallbox (upgradable to 22kW) and charge at your own convenience. Unsurprisingly, the SQ8 doesn't fare as well as the 55 e-tron thanks to its additional power: 457 claimed kilometers for the SQ8 e-tron SUV, and up to 475km for the SQ8 e-tron Sportback.
Elsewhere it’s textbook Big Electric Car. Over 40 driver assistance systems spanning countless sensors. LED headlights. The interior is textbook Audi, featuring the crystal clear ‘Virtual Cockpit’ and 10.1- and 8.6-inch high-res displays, and carbon-neutral materials used for the interior which will no doubt be impeccably built. There’s voice control and remote parking will be available from next year.
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
Audi Q8 e-tron
PHOTO: TopGear.com
