Cross-segment comparo: Toyota Yaris Cross 1.5 V vs Toyota Corolla Cross 1.8 G
Which non-hybrid should you choose?
toyota yaris cross, toyota corolla cross side by side
ILLUSTRATION: Andrew Guerrero
The Yaris Cross fits in the tight gap between the smaller Raize and the larger Corolla Cross. It’s unavoidable that there will be an overlap between the different models.
Last time, we compared the base Yaris Cross to the top-spec Raize. This time, we’ll compare the mid-spec Yaris Cross 1.5 V CVT (P1,296,000) to the base Corolla Cross 1.8 G CVT (P1,312,000). The price gap between the two Toyota models is just P16,000, and if you opt for the Scarlet SE or Attitude Black Mica two-tone paint on the Yaris Cross 1.5 V, that gap shrinks to just P6,000. Which one is the better deal, at least on paper? Let’s dive in for a closer look.
How much could the Mitsubishi XForce be once it's launched here?
Actor Jake Cuenca gave the perfect gift to his mom
Toyota Yaris Cross 2024
The Yaris Cross is 4,310mm long, 1,770mm wide, and 1,615mm tall, this makes it 150mm shorter, 55mm narrower, and 5mm lower than the Corolla Cross. The subcompact SUV rides on a 2,620mm wheelbase, which is interestingly only 20mm shorter than its bigger sibling’s.
The Yaris Cross boasts a 212mm ground clearance, which is 51mm greater than that of the bigger Corolla Cross. The Yaris Cross 1.5 V comes with 18-inch alloy wheels on 215/55 R18 tires, while the Corolla Cross 1.8 G is equipped with smaller 17-inch alloys shod with 215/60 R17 tires, the same size as the 1.5 G variant of the Yaris Cross.
photo of the 2023 toyota corolla cross 1.8 g cvt
As a refresher, the new Yaris Cross V is powered by a 1.5-liter gasoline engine which puts out 105hp and 138Nm of torque, while the Corolla Cross G is powered by a larger 1.8-liter gasoline mill which produces 138hp and 172Nm of torque. Both front-wheel-drive Toyota SUVs are equipped with a continuously variable transmission.
The ASEAN Yaris Cross is built on the B-segment version of the DNGA (Daihatsu New Global Architecture) platform, while the Corolla Cross is built on the short wheelbase C-segment version of the TNGA (Toyota New Global Architecture) platform. Both Toyota SUVs use the same suspension layout, independent MacPherson struts up front, and a torsion beam setup at the rear. The Yaris Cross 1.5 V comes with six airbags, that’s one less than in the Corolla Cross G which gets a driver’s knee airbag. On the other hand, the subcompact SUV in V trim has a panoramic view camera which its bigger lower trim sibling doesn’t have. Each model has its strengths and weaknesses.
With a match this tight, we wouldn’t be surprised if you’re still undecided on which of the two Toyota SUVs is the better deal for you. Take a look at the spec-sheet we prepared below and let us know what you think.
Toyota Yaris Cross 1.5 V CVT
Toyota Corolla Cross 1.8 G CVT
Price (Philippine Peso) 1,296,000 1,312,000
Drive FWD FWD
Seating capacity 5 5
Engine Type 1.5-liter in-line-four gasoline 1.8-liter in-line-four gasoline
Power 105 138
Torque 138 172
Fuel tank capacity (liters) 42 47
Transmission continuously variable transmission continuously variable transmission
Brakes (Front/Rear) disc/ disc disc/ disc
Wheels 18-inch alloy 17-inch alloy
Tires 215/55 R18 215/60 R17
Front suspension Independent MacPherson strut Independent MacPherson strut
Rear suspension Torsion beam Torsion beam
Seat material Synthetic Leather Fabric
Infotainment system 10.1-inch touchscreen 6.9-inch touchscreen
Connectivity Apple Carplay + Android Auto Apple Carplay + Android Auto
Push Start Yes Yes
Airbags 6 7
Electronic Stability Control Yes Yes
Hill-start Assist Yes Yes
Camera Panoramic view Rear
Parking Sensors Front + Rear Rear
Headlights LED Halogen Projector
Dimensions (mm) 4,310 x 1,770 x 1,615 4,460 x 1,825 x 1,620
Wheelbase (mm) 2,620 2,640
Ground Clearance (mm) 212 161
  • 1.8 E CVT
    1.8 E CVT
    1.8 E CVT
    Price
    ₱2,100,000
    ₱2,100,000
    ₱2,100,000
    Engine
    Inline 2
    Inline 2
    Inline 2
    Power
    160hp
    160hp
    160hp
    Torque
    200nm
    200nm
    200nm
    Transmission
    CVT
    CVT
    CVT
    Fuel
    Diesel
    Diesel
    Diesel
