This sublime Honda Integra Type R restomod takes us right back to the ’90s
One of the very best FWD performance cars ever built
Photo of the Tolman Honda Integra Type R Restomod
PHOTO: TopGear.com
The Honda Integra Type R is widely considered to be one of the finest front-wheel-drive performance cars ever built. Which makes this particular example one of the finest of the finest, because it’s been rebigulated by noted rebigulators Tolman.
That’s the same Tolman that worked a bit of magic on the Peugeot 205 GTI a while back, and has here subjected an owner’s Integra Type R to a “sympathetic restomod.” Unsurprisingly, this owner also has a Tolman 205 GTI in the garage.
The treatment, then, is less ‘shove a V6 inside a bespoke racing shell and clothe it in expensive carbon-fiber panels,’ and more along the lines of something you’d basically want to do to your own modern classic.
The all-new Nissan NX8 comes as a 1,450km range-extended hybrid or a 650km EV
BYD just launched a performance version of the Shark 6 with 469hp and 700Nm
Tolman stripped the whole thing down to discover a fair bit of rust lurking underneath, so it repaired and remade structural bits, and then future-proofed it using tons (not literally) of underseal. That alone took 180 hours of labor.
Then came the color. The Integra was originally Championship White, but because said owner already owned said Tolman 205, the Honda was paint-matched to that car’s Sorrento Green.
The hand-built 1.8-liter VTEC four-cylinder engine was rebuilt and subtly enhanced to match what it delivered the day it was made—190hp. Elsewhere, brake and fluid lines were replaced, the suspension was refurbished (new springs, bushes, and Nitron dampers), and the wheels were refinished and shod in modern rubber.
While the rear seats were in “excellent” condition, the fronts...were not. So, Tolman sourced new-old seat material from Australia to retrim them. All in, Tolman expended 740 hours (and a no doubt thoroughly enjoyable 160km validation run) restoring the old Japanese hero to something that’s daily-drivable.
“The brief started with a color change to sit alongside the owner’s Tolman Edition 205 GTI, but once we stripped the car, we could see it deserved the full job done properly,” said Chris Tolman.
“When the panels are not available, you either compromise or make them yourself. We’ll never compromise, so the answer was clear. The result is a build that stays true to the Integra, is sharp to drive, and can be used with confidence.”
It’s the first of four one-off customer commissions Tolman will do this year, alongside building that 205, too.
More photos of the Honda Integra Type R restomod by Tolman:
PHOTO: TopGear.com
