Size comparo: How big is the all-new 2024 Toyota Land Cruiser Prado versus its predecessor?
Hows does the all-new Prado size up against the old one?
Old vs. New: Toyota Land Cruiser Prado
PHOTO: Toyota ILLUSTRATION: Andrew Guerrero
One of the most awaited new SUVs to be launched this year is the all-new 2024 Toyota Land Cruiser Prado. The latest generation, known as the Series 250 in Toyota’s language, has gone back to its rugged roots.
For this size comparo, we’ll be pitting the all-new 2024 Land Cruiser Prado (Series 250) against the outgoing 2023 Land Cruiser Prado (Series 150).
UPDATE: Parts of Ongpin, Quintin Paredes in Binondo closed due to fallen posts
Toll collection on NLEX-SLEX Connector begins on August 8
The all-new Prado is 4,925mm long, 1,980mm wide, and 1,870mm tall, this makes it 100mm longer, 95mm wider, and 20mm taller than the model it replaces. Note that the height figures don’t include the roof rails. Toyota’s new SUV was also given a low cowl and beltline to improve visibility. The all-new Prado rides on a 2,850mm wheelbase, this is 60mm greater between axles than its predecessor. Most variants of the all-new Prado are expected to get larger diameter tires. The all-new Prado prototype seen in the photos roll on 265/70R18 tires which have a diameter of 32.6 inches, this is 1.1 inch taller than the outgoing Prado’s 265/55R19 rubber.
The all-new Series 250 Prado features boxy styling with design elements inspired by other rugged Land Cruisers like the Series 70 as well as the older Series 60 and Series 40. This is a huge departure from the rounded outgoing Series 150 Prado which was essentially a junior version of the comfort-oriented Land Cruiser. Although not present on the prototype, options like a moonroof, roof rails and 20-inch alloy wheels shod with 32.5-inch diameter 265/60R20 tires will also be available.
Here's a little refresher for the all-new Series 250 Prado. The new Toyota four-wheel drive SUV adopts the TNGA-F platform also used by its Lexus GX twin, the larger Land Cruiser Series 300, and the Lexus LX. The all-new Prado retains the independent front double-wishbone suspension and coil-sprung multi-link solid axle setup of its predecessor. The all-new Prado will be offered in five-seater and seven-seater layouts.
Front quarter image of the Toyota Land Cruiser 250 Series 2024, aka the Toyota Land Cruiser Prado
The all-new Prado’s 4-cylinder-only engine lineup ranges from a 161hp naturally aspirated 2.7-liter gasoline mill all the way up to a 326hp 2.4-liter turbo hybrid, the latter is sadly reserved for North America and China. If it were to be sold here, what engine options could we get? My guess, the familiar 201hp 2.8-liter turbo diesel and probably the 277hp turbo four gasoline unit.
What do you think of the all-new rugged boxy Prado. Do you prefer it over the outgoing model? Let us know in the comments.
