The Porsche Macan EV will get up to three screens and over 1,000Nm of torque
And there’ll still be a separate climate control panel with buttons
Tracking image of the Porsche Macan EV
PHOTO: Porsche
Porsche has been slowly drip-feeding us information about its all-electric Macan for what seems like decades. But now there’s been a rather large dump of technical info, and we get to see the production car’s interior for the first time, too!
Let’s start with the inside. As you can see, the Macan EV (not its official name; currently, Porsche is referring to this thing as ‘the new Macan’) will get an interior that looks remarkably similar to the one in the Taycan, the Cayenne, and the upcoming Panamera. That means there are up to three screens. The 12.6-inch digital dial display and 10.9-inch central touchscreen are both standard, while the second 10.9-inch passenger touchscreen is optional and uses a special film to stop the driver from seeing its contents. Still a separate climate control panel with buttons, though. Good news.
Cockpit of the Porsche Macan EV
Augmented-reality heads-up display of the Porsche Macan EV
Porsche has also let slip that it will offer an augmented-reality heads-up display for the first time on this Macan, with navigation arrows and driver-assist functions being displayed closer to the driver’s line of sight.
Confirmed: Hyundai to launch all-new Santa Fe in PH in Q1 2024
The V8-powered Land Rover Defender will cost you P17.79-M in PH
What else? Well, there’s a light strip with 56 LEDs that runs right across the front of the interior and communicates greetings, warnings, or charging states and the like. Oh, and you’ll have access to the new Porsche App Center where you can download third-party apps like BBC Sounds, Spotify, YouTube, or even TikTok. Uh-oh. We’re also told there’s updated voice control tech and that the whole infotainment system has been upgraded to be much quicker. Plus, there’s much more of a sloping coupe-like roofline than you might expect.
Porsche Macan EV powertrain tech
So, to the powertrain. We already knew the Macan would be built on the Premium Platform Electric (PPE) platform that Porsche has developed in partnership with Audi. We also knew that it would have a fancy 800V architecture for 270kW rapid charging, and that it would be able to split its 100kWh battery into two banks that can charge simultaneously when a charger is only capable of 400V. Clever.
Porsche currently says that in the top-spec (Turbo S?) trim, “peak power will be roughly 603hp,” and we’re told that max torque will be more than 1,000Nm. Yikes. We’ll see that and an entry-level variant with a less powerful rear motor at launch, with the range-topper also getting an electronically controlled diff lock on the rear axle as standard. And after a quick passenger ride in said version, we can confirm that it’s rather rapid.
Image of Porsche Macan EV on track
When you want to stop the thing, the Macan will be capable of 240kW of regen, and to aid maneuverability, there will be optional rear-wheel steering that reduces the turning circle by over a meter and should aid stability at highway speeds. Yep, in a Macan! Air suspension will be standard on top-spec versions and optional elsewhere, and it’ll give you the ability to raise the car by up to 40mm in off-road mode or drop it by 30mm in sport mode.
Think this all-electric Macan will be a success?
More photos of the Porsche Macan EV:
Front-quarter image of the Porsche Macan EV
PHOTO: Porsche
