Spec-sheet brawl: Isuzu D-Max vs. Nissan Navara vs. Ford Ranger vs. Toyota Hilux
Damn
PHOTO: Ford, Nissan, Toyota, Isuzu
The pickup wars have begun...again.
An all-new Isuzu D-Max, yet another Ford Ranger variant, and beefier Nissan Navara and Toyota Hilux updates? Frankly, the segment hasn’t been this hot since several years ago when most of these names—save for the D-Max, which is the only all-new competitor in today’s spec-sheet brawl—were “next-gen.”
And you know what? We’re grateful. All the top dogs in the midsize-pickup segment have something new to offer, and anyone who has been saving up for a workhorse is once again spoiled for choice. Now, the problem is making sure you make the correct one. The spec-by-spec breakdown below should make things easy for you guys. Let’s go through some of the basics.
Power-wise, the Ranger still reigns supreme. The Wildtrak 4x4 AT variant is what we’ve included here, and its 2.0-liter bi-turbo diesel engine with 210hp and 500Nm of torque sends more oomph to all four wheels than the rest of the competition does. Next up in this department is the Hilux Conquest 4x4 AT and its 2.8-liter turbodiesel capable of 201hp and 500Nm. The top-spec D-Max LS-E 4x4 AT and the Navara Pro-4X have the most modest output of the bunch, both with 187hp and 450Nm courtesy of 3.0-liter and 2.5-liter engines, respectively.
The Isuzu and the Nissan, though, have the edge when it comes to safety. These two Japanese trucks offer advanced safety tech like lane-departure warning, forward-collision alert with autonomous emergency braking, and rear cross-traffic alert, among others. The Ranger is missing just rear cross-traffic alert, while none of these features are present in the Hilux.
We could go on and on here mentioning specs, but you’re probably better off checking them all out side-by-side in the table below. So, which one are you going with? Let us know in the poll below, and sound off in the comments section.
The 2021 Pickup Comparison Sheet
2021 Isuzu D-Max 3.0 LS-E 4x4 AT
2021 Ford Ranger 2.0 Bi-turbo Wildtrak 4x4 AT
Nissan Navara 2.5 Pro-4X 4x4
Toyota Hilux 2.8 V Conquest 4x4 AT
Price P1,825,000 P1,728,000 P1,849,000 P1,850,000
Drive 4WD 4WD 4WD 4WD
Seating capacity 5 5 5 5
Engine setup 3.0-liter in-line-four turbodiesel 2.0-liter bi-turbo diesel 2.5-liter in-line-four turbodiesel 2.8-liter in-line-four turbodiesel
Power (hp) 187 210 187 201
Torque (Nm) 450 500 450 500
Transmission 6-speed automatic 10-speed automatic 7-speed automatic 6-speed automatic
Fuel tank capacity (L) 76 80 80 80
Brakes (front/rear) ventilated discs/auto-adjust drum ventilated discs/drum ventilated discs/drum ventilated discs/drum
Wheels 18-inch alloy 18-inch alloy 17-inch alloy 18-inch alloy
Tires 265/60 R18 all-terrain 265/60 R18 255/65 R17 all-terrain 265/60 R18
Front suspension double-wishbone with coil springs, high-mounted upper control
arm, and stabilizer
double-wishbone with coil springs double-wishbone with coil springs double-wishbone
Rear suspension long-span semi-elliptical
soft-ride leaf springs
leaf springs multilink with coil spring and stabilizer leaf springs
Seat material leather leather leather fabric
Tilt/Telescopic steering wheel adjustment yes/yes yes/no yes/no yes/yes
Paddle shifters no no no no
Infotainment system 10.1-inch touchscreen, 8-speaker setup 8-inch touchscreen, 6-speaker setup 8-inch touchscreen, 6-speaker setup 8-inch touchscreen, 6-speaker setup
Apple CarPlay/Android Auto yes/yes yes/yes yes/yes yes/yes
Smart keyless entry yes yes yes yes
Push-start ignition yes yes yes yes
Remote start yes no no no
Parking brake mechanical mechanical mechanical mechanical
Automatic climate control yes, dual-zone yes, dual-zone yes, dual-zone yes
Automatic headlamps yes yes yes yes
Power-folding side mirrors yes yes yes yes
Rain-sensing wipers yes yes yes no
ABS w/ electronic brakeforce distribution yes yes yes yes
Electronic Stability Control yes yes yes yes
Hill-start assist yes yes yes yes
Hill-descent control yes yes yes yes
Cruise control adaptive adaptive yes yes
Blind Spot Monitor yes no yes no
Lane-keep/lane-change assist lane-departure warning only yes lane-departure warning only no
Forward-collision alert w/autonomous emergency braking w/autonomous emergency braking w/autonomous emergency braking no
Rear cross-traffic alert yes no yes no
Tailgate lift assist no yes yes yes
Parking assist front and rear cameras active park assist w/front and rear sensors, reversing camera around-view monitor with parking sensors reverse camera with rear sonar
Airbags 7 6 6 7
Dimensions (mm) 5,277 x 1,880 x 1,810 5,354 x 1,860 x 1,848 5,260 x 1,875 x 1,855 5,325 x 1,900 x 1,845
Wheelbase (mm) 3,125 3,220 3,150 3,085
Ground clearance (mm) 240 232 220 N/A
