Specs, prices, features: Everything you need to know about the 2024 Nissan Almera
For those curious about Nissan’s new subcompact sedan
Nissan Almera 2024
PHOTO: Leandre Grecia
Nissan Philippines (NPI) is starting off the second half of 2023 on a high note as it introduces the facelifted Almera. Shortly after its arrival in ASEAN, the subcompact sedan now makes its debut in our market bearing new looks and added tech.
We reckon many of you are looking forward to seeing what this new car has to offer, so let’s stop beating around the bush—let’s take a deep dive into the facelifted Nissan Almera.
First drive: Nissan Almera 2024
First drive: The Zenix is one heck of a gamble for Toyota
Bianca Bustamante nabs second F1 Academy win at Monza
Variants and prices
Nissan Almera 2024
There will be three variants in the Almera range, starting with the EL MT—yes, there will still be a manual version available—that stickers for P839,000. The new top-spec trim will be the VL CVT which goes for P1.149 million. You can check out the full price list below:
Nissan Almera 2024 prices
  • Nissan Almera 1.0 VL CVT – P1,149,000
  • Nissan Almera 1.0L VE CVT – P1,059,000
  • Nissan Almera 1.0 EL MT – P839,000
Exterior
Nissan Almera 2024
Seeing as this is only a facelift, the Almera retains its shape and silhouette. The changes up front, however, are impossible to miss. The V-Motion grille on the new Almera now features horizontal slats instead of the V-shaped chrome and gloss-black plastic trim enclosing the mesh grille on the pre-facelift model.
As expected, the Almera’s dimensions remain the same. It still measures 4,530mm long, 1,740mm wide, and 1,460mm tall, with a 2,620mm wheelbase and 135mm ground clearance.
The new Almera also comes in a variety of colors. Available across the range are Brilliant Silver, Pearl White, and Galaxy Black. The VL variant can be had in Moon Pearl Gray and Fiery Cayenne Red, while the VE and EL  Gun Metallic.
PH-spec 2023 Honda City to get Honda Sensing on all variants
Size comparo: How big is the GAC Emkoo versus the new Ford Territory?
Interior
Nissan Almera 2024
The facelifted Almera also retains its interior design. Same layout for the dash, same look for the center console. What’s worth noting here, though, is that the higher-spec Almeras are available with two-tone finishes inside the cabin.
Of course, same head- and legroom are available inside. At the back, you’re still looking at 474 liters of cargo space.
Engine and specs
Nissan Almera 2024
The Almera also packs a familiar 1.0-liter turbocharged three-cylinder gasoline that generates 99hp at 5,000rpm and 152Nm of torque at 4,000rpm. This is mated to either an Xtronic CVT or a five-speed manual gearbox. The latter bumps maximum torque output up to 160Nm.
Underneath, the Almera is fitted with independent MacPherson struts with stabilizers up front and a torsion beam with stabilizers out back. Ventilated disc and drum brakes at the front and rear, respectively, handle stopping duties.
The Almera also gets a choice of 15-inch steelies or 15- or 16-inch alloy wheels, depending on the variant.
Guide: How to settle Manila City traffic violations online
We imagine the next-gen Toyota Land Cruiser Prado as a rugged, boxy SUV
Extra features
Nissan Almera 2024
The updated sedan still features a bunch of safety features that come courtesy of the Nissan Intelligent Mobility suite. There’s forward-collision warning with autonomous emergency braking, blind-spot warning, rear cross-traffic alert, and a 360-degree-view monitor that are available depending on the trim. ABS with EBD, vehicle dynamic control, and hill-start assist are all standard.
New for this Almera is the addition of Android Auto connectivity to the Apple CarPlay-ready eight-inch infotainment system for VE and VL variants. A wireless charger is now also available for these trims. A tire-pressure monitoring system, high-beam assist, and lane-departure warning to go along with six airbags now also come as standard in the sedan.
Arguably the biggest change for the new Almera, however, is the introduction of Nissan Connect Services in the top-of-the-line variant—a first for NPI. This enables connectivity between the car and a smartphone via a dedicated app. The app then allows features such as remote lock/unlock and engine start and automatic collision notification, among many others.
Nissan Connect Services also allows owners to monitor their cars’ health and maintenance schedules through the app. This app can now be downloaded via Google Play or the App Store. Each purchase of the top-spec Almera also comes with a three-year subscription.
You can also check out more photos of the sedan below.
More photos of the Nissan Almera 2024:
Nissan Almera 2024
Nissan Almera 2024
Nissan Almera 2024
Nissan Almera 2024
Nissan Almera 2024
Nissan Almera 2024
Nissan Almera 2024
Nissan Almera 2024
Nissan Almera 2024
