Do you know what those colored dots on the sides of new tires are for?
Should you pay attention to these?
PHOTO: Joey Bernardez
The other day, I was at a tire shop and was watching as tires were being mounted for another customer. I noticed that the technician doing the mounting wasn't paying attention to the alignment of the dots on the sidewall in relation to the wheel. I found out about these dots a long time ago, and I've gone through so many tires that this is a matter of course to me. However, it seems that not many people are aware of the function of these dots. Knowing what they're for and how to use them properly can save you money.
On the sidewall of most new tires are red and yellow painted dots. These are markers or guides to be aligned with particular points on the wheel. The alignment matters for the balancing of the wheel: If these dots on the tires are properly aligned with certain points on the wheel, minimal weights will be used for balancing. The less lead used for wheel weights, the lower the cost for balancing. The more weights are used, the higher the cost to balance your tires.
The yellow dot
When tires are made, they are almost never perfectly balanced. Most manufacturers will place a yellow dot on the section of the tire where there is least weight. The technician is then supposed to line up this yellow dot to where the valve stem is located. Where the valve stem is located is the heaviest point of the wheel. By aligning the lightest spot on the tire with the heaviest point on the wheel, the tire/wheel balance is as close to optimal as can be. As such, you won't be using as many lead weights around the wheel to balance out the tire and wheel. Using fewer weights means you get a more balanced wheel, which then means a quieter, more comfortable ride, and a longer-lasting tire. All these add up to significant savings for the user.
Quick guide: How to apply for a number coding scheme exemption
The red dot
In the same way tires are never perfectly balanced from the manufacturer, tires are never perfectly round, either, even when new. They have high and low points because of where the belts are joined, and these points can cause vibrations when a tire is rolling. The red dot indicates the tire's high point. Most of the time, a wheel will also have a dot—either a drilled dot or a sticker to indicate its low point. If you have these marks, you should align the red dot with the mark on the wheel. By doing this, you minimize the vibration caused by the high point of the tire. Minimized vibration is a good thing and ultimately also saves you money.
Red over yellow
Now, if you have both red and yellow dots on your tire and you don't have any dots or marks on your wheel, red takes precedence over yellow and you should align the red dot with the valve stem. Canceling out the high point takes precedence over the lightest point of the tire, which can be addressed with wheel weights.
So the next time you have tires mounted, make sure the technician follows these tips. You will get a smoother ride for less money, and your tire will also last longer.
