We’ve seen the arrival of 300c maxi-scooters over the past few years such as those Kymcos and BMWs. “Hindi pa ginawang expressway-legal” is the usual response from most people, but the fact that Filipinos are still buying these bikes proves that there’s actually a market for them here.
Now, if we could have our way, we’d have Honda Philippines (HPI) bring the ADV 350 here. We’ve noticed that people have been constantly searching and reading about this model on our website since its launch last year, and we reckon it could be worth the shot. It could bridge the gap between small-displacement scooters and big bikes, catering to riders looking for a sizeable adventure/maxi-scooter to use solely around the metro.
We’re sure a lot of you are eager to learn more about the Honda ADV 350, so we’ve compiled here everything you need to know about it. Read on to learn more.
OTHER HONDA MOTORCYCLE STORIES YOU MIGHT WANT TO READ:
Long-term review: 2020 Honda ADV 150
Specs, prices, features: Everything you need to know about the Honda PCX160
Pricing
As mentioned, the ADV 350 still isn’t available in the Philippines. But in Europe, there’s one variant of the scooter that sells for £5,699. In local currency, that’s about P377,000. We doubt that would be the case if HPI were to bring this in, though. We’re guessing somewhere around P400,000, if not higher.
There are three color options available: Spangle Silver Metallic, Mat Carbonium Gray Metallic, and Mat Carnelian Red Metallic.
Design and dimensions
The Honda ADV 350 stands 2,200mm long, 895mm wide, and 1,430mm tall. For context, its ADV 150 sibling measures 1,950mm x 763mm x 1,153mm, so there’s a significant size difference here.
The ADV 350 has a 1,520mm wheelbase and 795mm of ground clearance. Curb weight is listed at 186kg. The scooter sits on 15-inch front and 14-inch rear wheels shod in 120/70-15MC 56P and 140/70-14MC 62P tires, respectively.
In terms of design, the ADV 350 looks closer to the X-ADV than to the ADV 150. The ADV 350 borrows its bigger sibling’s overall styling, with the former boasting X-ADV-like LED headlamps up front. The exterior also gets black and gray plastics that further accentuate the look.
Other bits here are pretty standard stuff. There are sizeable stepboards for the rider and foldable footpegs and grab bars for the passenger.
The Honda CB150X is now in PH with a P163,900 price tag
Honda unveils the updated CB300R
Engine and specs
The ADV 350 is powered by a 330cc liquid-cooled, single-cylinder Euro 5-compliant engine. This is capable of 28.8hp at 7,500rpm and 31.5Nm of torque at 5,250rpm. The scooter has an 11.7-liter gas tank. Fuel consumption is supposedly around 29.4km/L.
Stopping power is provided by a 256mm front and 240mm rear disc brakes. The suspension setup is comprised of front upside down forks and twin shock absorbers at the back.
Extra features
Like its stablemates, the ADV 350 boasts a host of amenities including the full LCD display with two trip meters, a fuel-consumption gauge, and Honda RoadSync. This smartphone-connectivity function allows the use of navigation, music playback, messaging, and calls through the instrument cluster.
It also has a keyless ignition and a smart key with an answer-back feature. The latter also controls the smart top box that comes as an added option. A USB-C charging port is installed in the front glove box, and the 48-liter underseat compartment has space enough for two full-face helmets.
So, do you think HPI should bring in this scooter? Chime in through the comments section. You can also check out more photos of the ADV 350 below.
Driver follows navigation app, ends up on train tracks
Here’s your first look at the ASEAN-spec Honda CR-V
More photos of the 2022 Honda ADV 350:
