This is finally it. After some waiting, Toyota Motor Philippines (TMP) has now launched the all-new Lite Ace.
This light commercial vehicle is a returning nameplate in our market. But once known as a tiny and budget-friendly barkada-slash-family van, this vehicle now arrives as a light commercial vehicle ready to take on the likes of the Suzuki Carry.
We know a lot of you are eager to learn more about TMP’s newest offering, so without further ado, here’s everything you need to know about the Toyota Lite Ace.
Ouch: Lamborghini Aventador S loses its rear wheel while driving on EDSA
Rather than destroy seized cars, the Bureau of Customs will auction them off instead
Variants and prices
It seems the initial details we published check out. At launch, TMP has two Lite Ace variants available: a pickup and a panel van. The range starts at just over half a million pesos. You can check out the prices below, and have a closer look at the different body styles via our gallery and quick video.
Toyota Lite Ace 2023 Prices:
- Toyota Lite Ace 1.5L Panel Van MT – P655,000
- Toyota Lite Ace 1.5L Pickup MT – P570,000
Exterior
There’s really not a lot to talk about here in terms of styling. The Lite Ace has a very utilitarian design and is as simple as it gets in this regard. What’s important to talk about here are the dimensions.
The panel van variant stretches 4,045mm x 1,665mm x 1,930mm, while the Pickup measures 4,195mm x 1,675mm x 1,920mm. The former has a 790kg payload capacity while the latter can load up to 950kg worth of cargo.
Both vehicles sit on 14-inch steelies, but the Panel Van’s wheels are shod in slightly narrower rubber.
Interior
The inside is just as simple as the outside. Two seats come as standard, both of which are stitched in PVC fabric. There’s better legroom than expected, though, as the stick shift is mounted higher up on the dash, not on the floor—think of a Hiace-like layout.
Speaking of the dash, this one’s all covered in hard plastic. Worth noting, though, is the availability of cupholders on both sides of the front row, as well as a small cubby on the passenger-side dash.
LTO extends registration validity of vehicles with plates ending in 7 to August 31
Validity of driver’s licenses, student permits expiring in July extended for two months
Engine and specs
Powering the Lite Ace is a 1.5-liter in-line-four gasoline engine that generates 97hp at 6,000rpm and 134Nm of torque at 4,400rpm. This comes mated to a five-speed manual transmission that sends power to the rear wheels. This is the lone configuration available in the lineup.
The suspension setup is composed of MacPherson struts up front and a leaf spring at the rear for the pickup. The panel van features a rear 5-link coil spring. Stopping power is handled by front disc and rear drum brakes. The Lite Ace carries a 45-liter fuel tank.
Extra features
As expected, not a lot of toys and amenities here in the Lite Ace either. There’s a 2DIN head unit with USB/Bluetooth/AUX function paired with a two-speaker setup. There’s air-conditioning, though, and the panel van even gets power door locks to boot.
Both variants get anti-lock brake systems (ABS) but only the panel van gets vehicle stability control (VSC).
So, what do you guys think of the new Lite Ace? Tell us what you think in the comments. You can also check out this quick comparo we did—rest assured, we’ve made sure the specs in that story are now accurate.
More photos of the 2023 Toyota Lite Ace:
