Spec-sheet brawl: Kia Stonic vs. Chevrolet Trax vs. Hyundai Kona
See how the new Kia stacks up against its competitors in this three-way comparo
ILLUSTRATION: Echo Antonio
In case you missed it, there’s a new crossover in town: the Kia Stonic. With its stylish design, tech-loaded cabin, and affordable price tag, it certainly looks like an interesting proposition in our market, especially for first-time car buyers.
And as always with these new vehicles, we pulled out the spec sheets straight away to see how it stacks up on paper against its competitors. For the Stonic’s first bout, we decided to spice things up a bit with a three-way comparo, and we picked none other than the Hyundai Kona and the recently-updated Chevrolet Trax Premier to go against the newcomer.
For the purposes of this comparo, the variants we selected are the Kia Stonic 1.4 EX AT, the Chevrolet Trax Premier LS AT, and the Hyundai Kona 2.0 GLS. Let’s get to it.
Starting with what’s underneath, you won’t see a lot of differences between these three vehicles. All of them get disc brakes all around, 16- or 17-inch alloy wheels, and independent MacPherson struts up front with torsion or twist beams out back.
In terms of engine performance, though, you’ll see a significant gap. There’s only one turbocharged engine here, and that’s the Trax. The Chevy packs a 1.4-liter turbopetrol that generates 140hp and 200Nm of torque. It trumps the Stonic’s 99hp, 132Nm 1.4-liter nat-asp four-banger as well as the Kona’s 179Nm 2.0-liter in-line-four mill. The Kona gets the slight edge in horsepower, though, with 147hp on tap.
Now, moving on to extra features, things get pretty interesting, because it’s almost as if each vehicle has something going for it that its competitors don’t. For example: Only the Stonic gets an up-to-date eight-inch infotainment system with both Apple CarPlay and Android Auto.
The Trax, meanwhile, is the only vehicle that boasts a cabin air purification system and a built-in dashcam. As for the Kona, it’s the only one that’s been fitted with cruise control and hill-descent control as added driver-assist features—the other two only get hill-start assist and no cruise control.
Price-wise the Kia takes the cake, and by a big margin. The top-spec Stonic is priced at P925,000, the base model Trax Premier at P1,185,888, and the lone variant of the Kona at P1,188,000.
But of course, pricing isn’t all there is to it. There are other factors to consider before you can say which of these three is the real winner here. On that note, we leave it to you to check out the full specs of each vehicle below. Take your pick, then tell us your answer afterwards.
2021 Kia Stonic 1.4 EX AT
2021 Chevrolet Trax Premier LS AT
2021 Hyundai Kona 2.0 GLS
Price (Philippine Peso) 925,000 1,185,888 1,188,000
Drive FWD FWD FWD
Seating capacity 5 5 5
Engine setup 1.4-liter in-line-four gasoline 1.4-liter in-line-four turbocharged gasoline 2.0-liter in-line-four gasoline
Power (hp) 99 140 147
Torque (Nm) 132 200 179
Transmission 6-speed automatic 6-speed automatic 6-speed-automatic
Fuel tank capacity (L) 43 53 50
Brakes (front/rear) Disc/disc Disc/disc Ventilated disc/disc
Wheels 16-inch alloy 16-inch alloy 17-inch alloy
Tires 195/60 R16 205/70 R16 215/55 R17
Front suspension Independent MacPherson strut Independent MacPherson strut Independent MacPherson strut
Rear suspension Torsion beam Twist beam Torsion beam
Seat material Fabric Fabric Fabric
Infotainment system 8-inch touchschreen with 6 speakers 7-inch Android touchscreen AM/FM stereo with USB, AUX, Bluetooth
Apple CarPlay/Android Auto Yes/Yes No/No No/No
Smart keyless entry Yes No Yes
Push-start ignition Yes No Yes
Automatic climate control Yes Yes No
Auto-folding side mirrors No No No
Automatic headlamps No Yes No
Cabin air purification system No Yes No
Tire pressure monitoring system No Yes No
Built-in dashcam No Yes No
ABS w/ electronic brakeforce distribution Yes Yes Yes
Traction Control No Yes No
Electronic Stability Control Yes Yes Yes
Hill-start assist Yes Yes No
Hill-descent control No Yes No
Cruise control No No Yes
Blind Spot Monitor No No Yes
Parking assist Reversing camera with rear parking sensors Rear parking sensors No
Seatbelt reminder -- Front and rear seats --
Airbags 2 6 6
Dimensions (mm) 4,100 x 1,735 x 1,533 4,248 x 2,035 x 1,674 4,165 x 1,800 x 1,550
Wheelbase (mm) 2,570 -- 2,600
Ground Clearance (mm) 185 -- 170
