Size comparo: How big is the BYD Atto 2 EV versus the Jaecoo J5 EV?
We also compare the Atto 2 with its bigger sibling, the Atto 3
Size comparo 2026: BYD Atto 2 EV vs Jaecoo J5 EV
ILLUSTRATION: Andrew Guerrero
We’ve recently seen the sudden arrival of affordable subcompact electric hatchbacks in our market, but what if you wanted something roomier with a more commanding view of the road? Welcome to the era of the electric subcompact crossover.
Back in April at the 2026 Manila International Auto Show, BYD first previewed its much-anticipated Atto 2, the brand’s first BEV offering in this segment. For this comparo, we’ll be pitting it against its equally anticipated rival, the Jaecoo J5 EV, which was previewed two months later at the 2026 Philippine International Motor Show. It’s a face-off between contenders from the established benchmark and the rising challenger.
The Atto 2 measures 4,310mm long, 1,830mm wide, and 1,675mm tall. This makes it 70mm shorter, 30mm narrower, and 25mm taller than the J5. The subcompact BYD’s overall height includes the shark fin antenna, which serves as its tallest point. Interestingly, the Atto 2 and the J5 have exactly the same 2,620mm wheelbase. The BYD has a 380-liter cargo capacity; this is 100 liters less than the Jaecoo. The Atto 2 also rolls on 27-inch-diameter 215/65 R16 tires—1.2 inches shorter than the 28.2-inch-diameter 235/55 R18 rubber of the J5. Laden ground clearance for the BYD is 150mm, which is 16mm lower than that of the electric Jaecoo subcompact. Note that we used overseas figures of similar variants to fill in the blanks.
The Jaecoo 6T REEV has been launched in Thailand; has up to 190km EV range, 850km combined
BYD expands its dealership network across the country with seven new facilities
Here’s a bonus comparison: The Atto 2 EV is 145mm shorter, 45mm narrower, and 60mm taller than the Atto 3. The smaller BYD rides on a 100mm shorter wheelbase than its larger sibling, and both have a laden ground clearance of 150mm.
Size comparo 2026: BYD Atto 3 EV vs Jaecoo J5 EV
Here’s a little overview of our two featured electric crossovers. Both of these BEVs have hybrid siblings; the Atto 2 has a DM-i PHEV version, while the J5 has an SHS-H full hybrid version. Both have front-mounted motors and are front-wheel-drive. As you’d expect from vehicles in this segment, both utilize unibody construction and MacPherson struts up front. Things are a bit different at the rear—the Atto 2 uses a torsion beam suspension, while the J5 is equipped with an independent multilink setup. The BYD has a 174hp motor, a 51.3kWh battery, and a 410km NEDC range, while the Jaecoo has a 208hp motor, a 58.9kWh battery, and a 461km NEDC range.
Official pricing for the Atto 2 EV has not yet been disclosed by BYD Cars Philippines as of this writing. For reference, the smaller Dolphin hatchback is now priced at P1.438 million and the larger Atto 3 SUV starts at P1.638 million. The Jaecoo J5 EV, on the other hand, has an indicative price of around P1.4 million.
The data makes one thing clear: The J5 is indeed a larger vehicle in almost every dimension compared to its BYD rival. With these figures laid out, would you still consider the Atto 2 over the J5 EV despite its smaller profile? Let us know what you think in the comments.
