Spec-sheet brawl: MU-X vs. Terra vs. Fortuner vs. Montero Sport
Can the all-new Isuzu now compete with other midsize SUVs in its segment?
It’s only been a few weeks since our last spec-sheet comparo, but we’re already back with another one. And this time, we have four midsize SUVs to pit against each other—including the all-new Isuzu MU-X.
We’ve picked the top-of-the-line Isuzu MU-X 3.0L 4X4 LS-E AT  for this brawl. As we’ve said, this is a four-way, so we have the Nissan Terra 2.5 VL 4x4 AT, the Toyota Fortuner 2.8 LTD 4x4 AT, and the Mitsubishi Montero Sport GT 4WD AT stacked against it.
The MU-X may have gotten an all-new engine, but its new 187hp, 450Nm 3.0-liter turbodiesel is only good for second place here. These figures are identical to what the Terra’s powertrain is capable of, only that one is a smaller 2.5-liter unit. Taking the win in this regard is still the Fortuner with its 201hp, 500Nm 2.8-liter turbodiesel. The Montero Sport, meanwhile, falls behind with its 178hp, 430Nm 2.4-liter engine.
If you’ve read about the tech that the all-new MU-X now comes with, then you know that it now has all the toys to go head-to-head with the best in its segment. That’s why here, this comparo remains fairly equal, as all four come loaded with driver-assist and active safety features.
The Fortuner used to lack blind-spot monitoring, autonomous emergency braking, and rear cross-traffic alert, but Toyota Motor Philippines has since added all these features with the recent update. The Terra, however, still lacks adaptive cruise control. The MU-X, meanwhile, basically has all the added tech that its competitors have on offer, save for the 360-degree camera and the paddle shifters.
As for the prices, the Isuzu MU-X stickers for P2,450,000. It’s now more expensive than the Fortuner, even after the recent price bump that got its tag up to P2,440,000. The Terra has a P2,339,000 SRP, while the Montero Sport retails for P2,298,000, making these two the more affordable vehicles here.
Which of the midsize SUVs is the best choice, You know the drill: Check out more details below, then tell us your pick through the survey afterwards.
Price (Philippine Peso) P2,450,000 P2,339,000 P2,440,000 P2,298,000
Drive 4WD 4WD 4WD 4WD
Seating capacity 7 7 7 7
Engine Type 3.0-liter turbodiesel I4 2.5-liter turbodiesel I4 2.8-liter turbodiesel I4 2.4-liter turbodiesel I4
Power 187 187 201 178
Torque 450 450 500 430
Fuel tank capacity (liters) 78 78 80 68
Transmission 6-speed automatic 7-speed automatic 6-speed automatic 8-speed automatic
Brakes (Front/Rear) disc/disc disc/disc disc/disc disc/disc
Wheels 20-inch aluminum alloy 18-inch alloy 18-inch alloy 18-inch alloy
Tires 265/50 R20 255/60 R18 265/60 R18 265/60 R18
Front suspension Independent double wishbone Independent double wishbone Independent double wishbone Independent double wishbone
Rear suspension 5-link live axle w/ coil springs Multi-link live axle w/ coil springs Multi-link live axle w/ coil springs Multi-link live axle w/ coil springs
Seat material leather leather leather leather
Infotainment system 10.1-inch touchscreen 9-inch touchscreen 8-inch touchscreen 8-inch touchscreen
Apple CarPlay/Android Auto yes/yes yes/yes yes/yes yes/yes
Push-to-start ignition yes yes yes no
Smart keyless entry system yes yes yes no
Parking assist reversing camera with parking sensors 360-degree camera with parking sensors 360-degree camera with parking sensors reversing camera with parking sensors
Cruise control adaptive yes adaptive adaptive
Airbags 6 6 7 7
ABS w/ electronic brakeforce distribution yes yes yes yes
Traction control yes yes yes yes
Electronic stability control yes yes yes yes
Hill-start assist yes yes yes yes
Hill-descent control yes yes yes yes
Blind-spot monitor yes yes yes yes
Lane-keep/lane-change assist yes yes yes yes
Forward-collision alert yes yes yes yes
Autonomous emergency braking yes yes yes yes
Rear cross-traffic alert yes yes yes yes
Dimensions (mm) 4,850 x 1,870 x 1,825 4,900 x 1,865 x 1,865 4,795 x 1,855 x 1,835 4,825 x 1,815 x 1,835
Wheelbase (mm) 2,855 2,850 2,745 2,800
