The new Audi e-tron GT is a 590hp electric beast
The Porsche Taycan’s cousin finally breaks cover
PHOTO: Audi
A Porsche Taycan too sporty for you? An RS7 to petrol-y? Well, the new Audi e-tron GT is right up your street. It’s not the first pure-electric Audi of course, that title goes to its ever-growing line-up of e-tron SUVs, but the first based on the J1 platform shared with the Taycan. The Taycan is Top Gear’s 2019 Car of the Year, remember, so this commonality is a Very Good Thing.
Let’s get the salient numbers out the way first. There will be two flavors of e-tron GT initially—e-tron GT quattro and RS e-tron GT. That’s right, this is also the first electric Audi to wear the RS badge. No pressure. Both have a motor at either end for four-wheel-drive, both have the same two-speed gearbox as the Taycan on the rear axle to elevate efficiency at higher speeds and both feature a 93kWh battery as standard—no shorter range 79kWh option like the Taycan here.
The Audi E-Tron GT angled rear view
The ‘quattro’ produces 469hp, or 523hp for a 2.5sec boost when you deploy launch control—enough for 0-100kph in 4.1sec and a top speed of 245kph. Too slow? The RS gets 590hp or 637hp on overboost making it the most powerful RS model to date, albeit in brief bursts, capable of 0-100kph in 3.3sec (half a second slower than the Taycan Turbo S) and a top speed of 249kph. Rib-crushingly quick, then, just not quite as sadistic as the Stuttgart flyer.
The Audi E-Tron GT angled front view
Resist your urges to boot it at every opportunity, and Audi claims a WLTP range of 488 kilometers for the quattro and 472 kilometers for the RS—the former a couple of kilometers more than the RWD-only entry-level Taycan, and the latter a 19km improvement on the equivalently-powered Taycan Turbo. Like the Taycan, an 800V architecture means DC charging at up to 270kW is possible, if you can find a point capable of it. At peak speeds that means 100 kilometers of range in just five minutes. Zap.
You’re probably starting to get the idea, the Audi is being pitched as more of a rapid GT than a four-door sports car like the Taycan. Fast, but not as fast as the Porsche. That theory plays out when you get the measuring tape out, too. The Audi is a fraction longer, a little narrower, and a few cm taller than the Taycan, there’s a bit of extra boot space, too—405 liters in the back, another 85 in the nose.
The Audi E-Tron GT profile view
Underneath there’s aluminum double wishbone suspension, an electronically controlled rear diff and adaptive air suspension as standard on the RS, four-wheel steering, and an “e-tron sport sound” for maximum sci-fi as options on both models, while the center of gravity—thanks to all those lithium-ion cells—is lower than the R8. For braking, there’s three options—steel discs, steel with a tungsten carbide coating (standard on RS, designed to resist rust if you’re a gentle driver and only using regen not physical friction to stop the car), and carbon-ceramics if you want to show off.
The Audi E-Tron GT angled top view
Then we get to the design. You can make your own mind up on that one, but I’m a fan. Pro-tip: try Tactical Green on the configurator, only for the brave. Wheels range from 19- to 21-inch, the larger rims with proper aero blades, matrix LED headlights are standard on the RS, with the sinister-sounding laser lights (doubling your high beam range) on the options list.
Note the grille—less cooling requirements means no need for Audi’s usual gaping single frame number, hence the block of body-colored trim under the badge. The sinewy creases above the arches are a personal highlight, so too the full-width rear light—just below the pop-up rear spoiler. Carbon wing mirrors and a full carbon roof are available on request, says Audi.
The Audi E-Tron GT full dashboard
On the inside, rear passengers are treated to the same ‘foot garage’ as the Taycan, a dimple designed into the skateboard battery to give your feet somewhere to go. Up front the dash is subtly tipped towards the driver, presenting them with a 10.1-inch touch display to go with the 12.3-inch ‘virtual cockpit’ screen behind the wheel. Cow skin is available, but Audi is keener to push its leather-free interior, made with a “high-percentage of recycled material.” Sound-insulating glass in the windscreen is standard and can be fitted to all windows as an option. We reckon not having a combustion engine will probably make it quiet enough.
Despite sharing its bones and gizzards with the Taycan, both cars won’t be built in the same place. The e-tron GT will be assembled alongside the R8 at Audi’s Neckarsulm factory, which puts a bit of a cap on the number it can build, initially at least. Audi reckons “something in the high four figures” a year is achievable—so a 10,000-unit ceiling—compared to the 20,000-odd Taycans Porsche flogged in 2020. And that number’s expected to grow substantially in 2021. So, modest ambitions from Audi to begin with, but then this is a €99,800 (quattro, P5.8 million)/€138,200 (RS, P8 million) car.
More photos of the Audi e-tron GT:
The Audi E-Tron GT front view
The Audi E-Tron GT angled profile view
The Audi E-Tron GT rear view
The Audi E-Tron GT driver's and passenger's seat
The Audi E-Tron GT passenger's seat POV
The Audi E-Tron GT front angled profile view
The Audi E-Tron GT rear angled view outdoor
two Audi E-Tron GT feature
two Audi E-Tron GT rear and front feature
The Audi E-Tron GT front view outdoor
The Audi E-Tron GT profile view while charging
The Audi E-Tron GT on  the road
The Audi E-Tron GT on the road rear view
PHOTO: Audi
